10 - DT/DM/UMC-350 - Chip Removal and Coolant
DT/DM/UMC-350 - Interactive Service Manual
  • 1 - DT/DM/UMC-350 - Introduction
  • 2 - DT/DM/UMC-350 - Specifications
  • 3 - DT/DM/UMC-350 - Installation
  • 4 - DT/DM/UMC-350 - Tool Changer
  • 5 - DT/DM/UMC-350 - Axis Motion
  • 6 - DT/DM/UMC-350 - Spindle
  • 7 - DT/DM/UMC-350 - Spindle Motor
  • 8 - DT/DM/UMC-350 - Lubrication Systems
  • 9 - DT/DM/UMC-350 - Electrical Control
  • 10 - DT/DM/UMC-350 - Chip Removal and Coolant
  • 11 - DT/DM/UMC-350 - Workholding
  • 12 - DT/DM/UMC-350 - Maintenance
  • 13 - DT/DM/UMC-350 - Autodoor and Auto Window
  • 14 - DT/DM/UMC-350 - Robot and Automation
  • 15 - DT/DM/UMC-350 - Enclosure
  • 10.1 Chip Removal And Coolant
  • 10.2 DT/DM - Side Chip Auger - Installation
  • 10.3 DT/DM - Rear Lift Auger - Installation
10.1 Chip Removal and Coolant
Click on the image below to access the Chip Removal and Coolant - Service Manual
DT/DM - Side Chip-Auger - Installation
AD0347
This procedure tells you how to install a side chip-auger system.
Machine Compatibility
Do this procedure on a DM-1 or DT-1 mill that was made after August, 2016.
Prerequisites
Needed parts:
  • For DT-1/DM-1 and DT-2/DM-2 side auger 93-1000200
For machines made prior to August, 2016 refer to Chip Auger - Installation CHC
Side Chip Auger Motor Installation
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
 Danger: When the machine is off, wait at least 5 minutes before you work in the control cabinet. This lets power dissipate from the machine. When the voltage indicator LED on the vector drive to goes off completely, it is safe to work in the control cabinet.
Disconnect the coolant hose [1].
Disconnect the cable for the coolant pump [2].
Remove the coolant tank assembly.
Remove the front cover for the front augers [3].
Remove and discard the auger cover plates [5]. Remove the used gaskets [4]
Install new gaskets [4] and the auger motors [6], and the motor adapters.
Torque the (4) socket-head cap screws (SHCS) for each auger motor. Refer to Haas Fastener Torque Specification. Use the value for steel.
Put the wires [3] from the motors [2] through the grommet [1] and into the side cable manager.
Attach a strip of foam tape [5] to the base casting.
Attach the rear cable manager [4] to the foam tape.
Put the motor cables into the rear cable manager.
Put the cables into the bottom of the control cabinet.
Auger Quad ChipC PCB Installation
Attach the (2) mounting brackets [1] to the cabinet.
Attach the I/O PCB cover [2] to the panel mounting brackets.
Open the I/O PCB cover [3].
Install the standoffs [4] to the rear wall of the control cabinet.
Attach the Quad-ChipC PCB [1] to the mounting holes on the I/O PCB cover.
Connect the power cable from P1 [2] on the I/O PCB to TB2 77/78 [3] on the transformer.
Make these connections on the Quad ChipC PCB:
  • auger power cable to P2 [1]
  • auger power cables and to P6 [2] and P7 [3]
  • over-current sensor cable to P8 [4]
Make these connections on the I/O PCB:
  • over-current sensor cable to P1 [5]
  • chipC en/rev cable to P37 [6]
Close the I/O PCB cover.
Tighten the (2) screws to hold the cover.
Side Chip Auger Installation
Remove the control skirt [1].
Remove the V-flange clamps [2].
Remove the chip chute extensions [3].
Install the (2) augers [4].
Use a coupler [2] to connect each auger [3] to the motor shaft [1].
Install the chip chute extensions.
Install the V-flange clamps.
Install the control skirt.
Put the coolant tank below the auger assembly.
Connect the coolant hose [4].
Connect the coolant-pump cable [5].
Set the main circuit breaker to the ON position.
Press [POWER ON].
Make sure the auger motors operate correctly.
Make sure the auger system has no coolant leaks
Conclusion
Set Parameter 209:3, ENABLE CHIP CONVEYR, to 1.
Update the configuration files. Refer to Patch File Load/Uninstall.
DM-1/DT-1 - Rear-Lift Auger - Installation
AD0350
This procedure tells you how to install a rear-lift auger system.
Do this procedure on a DM-1 or DT-1 that was made after August, 2016.
The machine must have a side chip-auger system installed. Refer to DM-1, DT-1 - Side Chip-Auger - Installation.
Tools Required
Floor jack, 2" x 4" x 24" (51 mm x 1 cm x 6 cm) wood
Push [POWER OFF].
If the machine has chip chute extensions [3], do these steps:
  • remove the V-flange clamps [2]
  • remove the chip chute extensions [3]
For all machines, do these steps:
  • remove the chip chutes [5]
  • remove the coolant guard [4]
  • discard the chip chutes [5], chip chute extensions [3], and coolant guard [4]
Disconnect each auger [2] from the coupler [1].
Remove the augers [3].
This makes the rear lift-auger installation easier.
Remove the used sealant from the base.
Install sealant tape on the base as shown.
Put a 2" x 4" x 24" (50 mm x 101 mm x 610 mm) block of wood [2] onto a floor jack [3].
Put the lift auger assembly [1] onto the wood block.
Caution: The lift-auger assembly is heavy. Get the aid of another person to lift the auger.
Use the jack to lift the assembly into position.
Attach the assembly to the base casting.
Remove the jack.
Attach the base [1] for the rear chip guard.
Insert the augers [2] into the drain holes.
Connect each auger [5] to the motor shaft [3] with a coupler [4].
Install the front auger-trough cover [1].
Install the rear auger-trough cover [2].
Put the auger cable [1] through the bottom of the control cabinet.
Connect the auger cable to the I/O PCB. P38 [2] for Classic Haas Control or P24 [3] for Next Generation Control.
Install the control skirt [1].
Attach the extension [4] to the chip chute [2].
Use the V-flange clamp [3].
Put the coolant tank [1] below the auger assembly.
Put the 18-gallon chip container [2] under the chip chute extension.
Connect the coolant hose [3].
Connect the coolant pump cable [4].
Press [POWER ON].
Start the auger.
Start the coolant.
Make sure the auger system operates correctly.
Make sure the auger system has no coolant leaks.
