1 - HPB - Introduction
Haas Press Brake - Operator's/Service Manual
  • 0 - HPB - Table of Contents
  • 1 - HPB - Introduction
  • 2 - HPB - Legal Information
  • 3 - HPB - Safety
  • 4 - HPB - Installation
  • 5 - HPB - Operation
  • 6 - HPB - Maintenance
  • 7 - HPB - Troubleshooting
  • 1.1 HPB Introduction
  • 1.2 AXES DEFINITIONS
  • 1.3 FEATURES
  • 1.4 HOW TO USE THIS MANUAL
1.1 HPB INTRODUCTION
Haas Press Brake - Introduction
Revision A - 06/2026
Under Construction
Overview
HPB 50-5
This operator’s manual supplement describes the unique features and functions of the Haas Press Brake HPB 50-5. Refer to the machine control manual for control operation, programming, and general system functionality.
The HPB 50-5 is a compact, high-precision press brake designed for forming small to medium-sized sheet metal components.
Machine Specifications (HPB 50-5):
  • Approximate Machine Weight: 7500lbs
  • Maximum Bend Length: 1600 mm
  • Main Motor Power: 8.5 kW
  • Hydraulic Oil Capacity: 120 L
  • Column Gap: 1200 mm
  • Throat Depth: 200 mm
  • Ram Stroke: 160 mm
HPB 170-10
This operator’s manual supplement describes the unique features and functions of the Haas Press Brake 170-10. Refer to the machine control manual for control operation, programming, and general system functionality.
The 170-10 is a high-capacity press brake designed for bending large and thick sheet metal components. It is engineered for demanding production environments requiring increased tonnage, longer bend lengths, and consistent performance under heavy workloads.
Machine Specifications (170-10):
  • Approximate Machine Weight: 21,000lbs
  • Maximum Bend Length: 3200 mm
  • Main Motor Power: 18 kW
  • Hydraulic Oil Capacity: 270 L
  • Column Gap: 2600 mm
  • Throat Depth: 400 mm
  • Ram Stroke: 200 mm
1.2 AXIS DEFINITIONS
HPB Axis Definitions
Under Construction
Press Brake axes define the controlled movements of the ram and back guage system. Each axis preforms a specific function that positions the tooling or workpiece, enabling accuarte part location, consistent bend angles and repeatable bending preformance.
Press Brake Axes  Axes Definition
Y1 & Y2 - Axis (The Ram) These axes control thevertical stroke and can be offset to allow for intentional tilting if needed.
X - Axis (Depth) This controls your flange length by moving the backgauge forwards or backwards.
R - Axis (Height) Moves the backgauge fingers up and down to accommodate different flange heights.
Z1 & Z2 - Axis (Lateral) Available on the HPB-170-10. Allows the fingers to slide left and right independently for complex, multi-stage setups across the bed.
V - +1 Axis (Crowning)  The V-axis is the "+1" It uses a wedge system to "crown" the bed upward, neutralizing flex ensuring the angle is even across the bend.
V-Axis Crowning
During long or high-tonnage bends, the press brake bed can flex under load. The V-axis (crowning) compensates for this deflection by adjusting the bed, helping maintain a consistent bend angle across the entire workpiece.
1.3 FEATURES
HPB Features
Under Construction
HPB Features
[1] Dalem Interface
[2] Material Rest
[3] Material Stop
[4] Lower Die
[5] Upper Punch
[6] Punch Release Handle
[7] Light Transmitter
[8] Oil Tank
[9] Proportional Valve
[10] Ram
[11] Control Cabinet
[12] Protective Side Door
How to Use This Manual
To get the maximum benefit of your new Haas machine, read this manual thoroughly and refer to it often.
IMPORTANT:  Before you operate the machine, read and understand the Operator’s Manual Safety chapter.
DECLARATION OF WARNINGS
Throughout this manual, important statements are set off from the main text with an icon and an associated signal word: “Danger,” “Warning,” “Caution,” or “Note.” The icon and signal word indicate the severity of the condition or situation. Be sure to read these statements and take special care to follow the instructions.
Description Example
Danger means that there is a condition or situation that will cause death or severe injury if you do not follow the instructions given.  DANGER: No step. Risk of electrocution, bodily injury, or machine damage. Do not climb or stand on this area.
Warning means that there is a condition or situation that will cause moderate injury if you do not follow the instructions given.  WARNING:  Never put your hands between the tool changer and the spindle head.
Caution means that minor injury or machine damage could occur if you do not follow the instructions given. You may also have to start a procedure over if you do not follow the instructions in a caution statement. CAUTION: Power down the machine before you do maintenance tasks.
Note means that the text gives additional information, clarification, or helpful hints. NOTE:  Follow these guidelines if the machine is equipped with the optional extended Z-clearance table.
Description Text Example
Code Block text gives program examples. G00 G90 G54 X0. Y0.;
A Control Button Reference gives the name of a control key or button that you are to press.  Press [CYCLE START].
A File Path describes a sequence of file system directories.  Service > Documents and Software >...
A Mode Reference describes a machine mode.  MDI
A Screen Element describes an object on the machine’s display that you interact with.  Select the SYSTEM tab.
System Output describes text that the machine control displays in response to your actions.  PROGRAM END
User Input describes text that you should enter into the machine control.  G04 P1.;
Variable n indicates a range of non-negative integers from 0 to 9. Dnn represents D00 through D99.
