7 - HPB - Troubleshooting
Haas Press Brake - Operator's/Service Manual
  • 0 - HPB - Table of Contents
  • 1 - HPB - Introduction
  • 2 - HPB - Legal Information
  • 3 - HPB - Safety
  • 4 - HPB - Installation
  • 5 - HPB - Operation
  • 6 - HPB - Maintenance
  • 7 - HPB - Troubleshooting
  • 7.1 Troubleshooting Table
  • 7.2 Troubleshooting Diagrams
7.1 troubleshooting table
Haas Press Brake - Troubleshooting
Revision A - 07/2026
Note: Before you begin troubleshooting, make sure all THREE E-stops are released (Foot pedal, User Interface, Control cab).
Once thats been done, press reset, turn oil pump ON, and press the green button on the lower right side of the control interface.
These steps must be done for the press brake to run properly.
Oil pump not delivering. Slider not moving. Oil pump rotation direction is incorrect Check the phase alignment of the power supply input.
Check SR5 (X7)(Check, material sensor).
The pusher collet stuck by bar material burrs failed to retract as a result.
1. Oil pump making abnormal noise.
2. Pressure gauge fluctuating wildly
3. Oil Pressure dropping or no discharge
1. Suction filter clogged
2. Oil level too low
3. Pump or suction pipe air-locked
4. Damaged internal pump parts
1. Clean the filter
2. Refill oil to the standard level
3. Replace the oil seal at the suction pipe joint or pump
4. Replace pump parts or pump
Hydraulic valve, pipe joints, and cylinder leakage
1. Loose screws or pipe joints
2. Damaged or aged seals
1. Tighten connection screws and pipe joints
2. Replace seals
Nopressure in the hydraulic system
1. Damping hole clogged, pressure relief valve spool jammed
2. Piston seal ring damaged, causing oil leakage
1. Clean damping hole and valve spools
2. Replace seal ring
Slider creeps at low speed
 1. Valve 4 balance pressure too low
2. Lower guide rail too tight
1. Increase balance pressure
2. Adjust lower guide rail
Slider drop
 1. Valve core is stuck.
2. Safety valve is leaking
3. Oil cylinder piston seal is leaking
1. Clean or replaceNo. 4 valve.
2. Clean or replaceNo. 3 valve
3. Replace the seal
7.2 troubleshooting Diagrams
Haas Press Brake - Troubleshooting Diagrams
This section provides the electrical schematics, hydraulic circuit diagrams, synchronization block diagrams, and valve block diagrams for the HPB 50-5 and HPB 170-10 press brakes. These diagrams are intended to assist with system operation, diagnostics, troubleshooting, and service procedures.
50-5 Electric Diagrams
Emergency Stop Safety Circuit
Auxiliary Control Circuits
Power Distribution Diagram
Pump Motor and Control Power Supply
Delem Controller and Hydraulic Valve Wiring
Display and Controller Communication Diagram
X-Axis Drive Wiring Diagram
R-Axis Drive Wiring Diagram
Z1-Axis Drive Wiring Diagram
Z2-Axis Drive Wiring Diagram
SLA-6 Wiring Diagram
Emitter and Receiver Wiring Diagram
170-10 Electric Diagrams
Hydraulic Circuit
Synchronization Block
Valve Block
