Auto Air Jet Blast - Installation - AD0057
Service Home How To Procedures Auto Air Jet Blast - Installation - AD0057
- Jump to Section - 1. Introduction 2. AJB - Installation (7 steps) 3. Test - AJB Back to Top
Recently Updated Last updated: 03/11/2026
Revision 1
AD0057
Rev B - 03/2026
This procedure tells you how to install the Auto Air Jet Blast (AJB) option on machines with a Classic Haas Control built after May 2013 or an NGC Lathe.  For Sub-Spindle Air Blast refer to Sub-Spindle Air Blast - Installation - AD0517 procedure.
Updated
  • 93-2202 OPTION,  AUTO JET BLAST (ST20 - 35/DS-30Y) - CHC
  • 93-1000273 AUTO JET BLAST - NGC
  • 93-1000272 OPTION, AUTO JET BLAST (DS-30Y Non-Reboot) - NGC
NOTE: Kit 93-1000272 includes installation hardware for both main spindle and sub-spindle Auto Air Jet Blast configurations.
For 93-1000272 and 93-1000273 kits ordered before Nov 12, 2023, the following parts need to be purchased:
  • 58-1677 FITG NPT1/4 X DIA .750 BKHD BRASS    QTY: 1
  • 58-0567 FITG PC3/8F NPT1/4M STR STL     QTY: 1
NOTE: For Reboot DS-30Y sub-spindle auto air jet blast, refer to  Sub-Spindle Air Blast - Installation - AD0517 procedure.
AJB - Installation
Push [POWER OFF].
Set the main circuit breaker to the [OFF] position.
 Danger: Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Close the primary air valve. This stops the air supply to the machine.
Remove the plug [1] from the jet blast port on the main spindle.
Install the compression fitting [2] in the main spindle jet blast port.
Install the blast nozzle [3] into the compression fitting [2].
Route the air hose from the compression fitting into the lubrication cabinet
For machines built after 04/03/2019
Remove the plug from the bulkhead next to the main spindle.
Install the bulkhead fitting [1] to the bulkhead the blast nozzle fitting [2] then the blast nozzle [3].
Note : Install the push to connect fitting on the back side of the bulkhead fitting [1] then connect the provided air hose and route it to the lube cabinet.
Put the red cable ties on the main spindle solenoid assembly.
Refer to the Air-Lube System decal inside the lubrication cabinet for correct solenoid placement.
Remove the fourth plug [1] from the bottom of the air distribution manifold.
Install the compression fitting [2] into of the air distribution manifold.
Install the AJB solenoid [3] with the red cable ties to the air distribution manifold. Tighten the nut on the compression fitting. Make sure the solenoid aligns with the other solenoids.
Connect the AJB solenoid cable to the electrical connector labeled "Main Spindle Auto Jet Blast".
Make sure the color of the cable tie and the color of the label are the same.
Set the main circuit breaker to the ON position.
Push [POWER ON].
NGC - Machines
  • Login to the HBC  Service Portal.
  • Download the option configuration patch files.
  • Load the option configuration patch file to the control.  Refer to the Next Generation Control - Configuration File - Download/Load procedure.
Test - AJB
Open the primary air valve. This supplies air to the machine.
Test the AJB:
  • M12: Main Spindle Air Jet Blast ON
  • M13: Main Spindle Air Jet Blast OFF
DS Machines:
  • M112: Secondary Spindle Air Jet Blast ON
  • M113: Secondary Spindle Air Jet Blast OFF
For more information regarding these M-codes refer to the Lathe Operator Manual.
