Chip Separator - UMC-400 Coolant Valve - Installation - AD0916
Service Home How To Procedures Chip Separator - UMC-400 Coolant Valve - Installation - AD0916
22.4 Chip Separator - UMC-400 Coolant Valve - Installation
AD0916
Revision A - 11/2025
This procedure will show you how to install a ball valve onto your UMC-400/SS to turn off the flood coolant going to the head of the machine.
This procedure applies to the following kits :
  • 93-5565 CHIP SEPARATOR SVC KIT UMC-400/SS
Machine compatibility
  • UMC-400/SS built after 04/30/2025
Assemble Fittings
Begin by connecting the ball valve [1] to the first male-to-male fitting [2]. Next, attach the check valve [3] to the same male-to-male fitting, ensuring the check valve is oriented toward the ball valve as shown in the diagram. Install the second male-to-male fitting [4] onto the outlet side of the check valve. Connect the 90° elbow fitting [5] to this second male-to-male fitting. Finally, secure the barb hose fitting [6] to the open end of the 90° elbow.
Removing Chip Separator Fittings
Remove all hoses from coolant separator. These would be the head coolant hose [1], the coolant wash down hose [2], and the coolant inlet hose [3] from the coolant pump.
Remove the two screws to remove the chip separator [1] from the machine.
Remove the wash down hose barb fitting [1] from the manifold on the chip separator manifold.
Remove the check valve fitting assembly [1] from the chip separator manifold.
Installing Ball Valve Fitting Assembly
Install the ball valve fitting assembly [1] into the top hole of the manifold.
Install the wash down hose barb fitting [1] onto the bottom spot of the chip separator manifold.
Reattach the chip separator [1] back on to the side of the machine.
Reinstall all the hoses back onto the chip separator. These would be the head coolant hose [1], the coolant wash down hose [2], and the coolant inlet hose [3] from the coolant pump.
Trim the head coolant and wash down hose if needed.
NOTE: Make sure the hoses are not kinked when reinstalling them onto the chip separator.
To properly connect the coolant hoses slip the hose clamp [2] on the hose then place a hose cap [3] on the fitting before joining both together. Crimp the hose clamp using a crimping tool [1] and give the hose a slight tug to ensure proper clamping.
Note : Ensure that the rounded edge of the hose cap [3]  is facing away from the hose.
Turn on the machine and verify that the system is leak free.
