Coolant Pressure Regulator Valve - Installation - AD0978
Service Home How To Procedures Coolant Pressure Regulator Valve - Installation - AD0978
24.4 COOLANT PRESSURE REGULATOR VALVE - INSTALLATION
Recently Updated Last updated: 06/11/2026
AD0978
Revision A - 06/2026
This procedure describes how to install a ball valve onto the coolant separator to allow manual control of coolant flow.
This procedure applies to the following kits :
  • 93-6528 COOLANT PUMP VALVE SVC KIT
Important : Make sure to depressurize the coolant system by using the washgun after turning off the machine before installation.
Release hose clamp [1] and remove coolant hose [2].
Remove cap [3].
Remove Barbed fitting [4] from coolant bypass valve.
Install the ball valve [1] onto bypass valve.
Reinstall barbed fitting [2] onto ball valve.
Install cap onto barbed fitting [3].
Important : Ensure the concave face of the hose cap [3] points toward the hose. Refer to the image.
Reinstall the hose and verify that the cap is facing the correct direction.
Slip the hose clamp [2] onto the hose near the end.
Install the hose onto the barbed fitting.
Crimp hose clamp using a crimping tool.
Lightly tug onto hose to verify a secure connection.
Turn on machine and run coolant through hose to verify there are no leaks.
Note : May need to cut hose to compensate for added length due to the addition of the ball valve.
DC-Series Installation
Note : The following procedure pertains to the DC-Series machines. The use of the cap and hose clamp will not be used in this procedure.
Remove elbow and coolant hose adapter fittings [1] from coolant bypass valve.
Note : Fittings [1] comes with two peices, do not seperate them.
Reinstall fitting [2] onto ball valve.
Install hose to fitting [2].
Lightly tug onto hose to verify connection.
