Desktop Mill Spindle Mount Plate - Replacement - AD0692
Service Home How To Procedures Desktop Mill Spindle Mount Plate - Replacement - AD0692
Recently Updated Last updated: 03/06/2025
AD0692
- Jump to Section - 1. Introduction 2. Spindle Mount Plate Removal (4 steps) 3. Spindle Mount Plate Installation (3 steps) Back to Top
This procedure will show you how to replace the the Haas Desktop Mill Spindle Mount Plate.
This Procedure Applies to the Following Parts:
93-3873 SPINDLE MNT,Z-AX SPACER KIT DESKTOP MILL
Push [POWER OFF].
Unplug the Desktop Mill.
 NOTE: Be sure to unplug BOTH the control pendant and the Desktop Mill power cords as current runs from the pendant to the mill.
First start by removing the power cable that connects to the spindle [1].
Loosen the four socket head cap screws [2]. This will reduce the tension on the spindle clamp, allowing the spindle to slide out.
Carefully set the spindle aside.
Remove and set the spindle clamp aside [1].
Remove the following dowel pins located at [2].
Remove the four soccet head cap screws [3].
Unscrew the 8 socket head cap screws and remove the spindle mount plate [1].
Uninstall the trip flag from the back of the spindle mounting plate [2].
Once the 8 socket head caps screws have been uninstalled remove the two linear guides [3, 4].
Using the new linear guides and hardware provided in the kit, install the 4 dowel pins into the new linear guides as illustrated [1].
Install the new linear guides onto the guide rails.
Align the mounting plate to the dowel pins on the lienar guides and re-install the fasteners to secure the mounting plate [1].
Re-install the trip flag for the limit switch [2].
Using the removed hardware, re-install the spindle clamp to the machine [1].
Re-install the spindle to the clamp and connect its corresponding power cable [2].
Note: Turn on the machine and command the spindle to run in order to verify it is operating correctly.
Note: Refer to the Desktop Mill Troubleshooting Guide for further information.
