Haas Cobot 30 (HC30) - Lathe - Installation - AD0801
Service Home How To Procedures Haas Cobot 30 (HC30) - Lathe - Installation - AD0801
- Jump to Section - 1. Introduction 2. Lathe Setup (6 steps) 3. Cobot Installation (6 steps) 4. Robot Safety Device 5. First Power-UP (9 steps) 6. Parts Table Assembly 7. Haas Robot - Quick Start Guide 8. Disable the Robot Back to Top
Recently Updated Last updated: 08/20/2024
AD0801
Under Construction
This procedure will show you how to install the Haas Cobot 30 (HC30).
Note: The Haas designed work cell made up of a CNC machine and a robot have been evaluated for compliance to CE requirements. Changes or variations to the Haas cell design should be evaluated for compliance to the applicable standards and are the responsibility of the user/integrator.
Machine Requirements:
  • 100.24.000.1001 version or higher
  • ST-20/25/28/30/35/40/45 Reboot Sheet Metal (Flat Face)
  • ST-20L thru ST-45L
  • Haas Autodoor
  • 34-349xB I/O board or later
  • 93-1000610 REMOTE JOG HANDLE TOUCH LCD (RJH-XL) REMOTE JOG HANDLE - XL
 NOTE: If the machine has the Parts Catcher option installed. The catch tray will interfere with the robot and will need to be removed. A custom sheet metal panel will need to be made to cover and seal the opening.
Tool Requirements:
  • Mini Flat Head Screwdriver
Fixing / Anchoring Requirements
  • The Haas 30KG Cobot (HC30) is configured and sold by Haas with a pedestal/table that is sufficiently stable when used according to Haas defined part size and weight limits
IMPORTANT: For more information directly on the Hans Cobot, refer to the HANS ROBOT OPERATION MANUAL FOR ELFIN SOFTWARE.
There are 3 scenarios in which the cobot option can be installed on a Haas machine:
  1. Cobot option was ordered at the same time as the machine. Both the cobot and the machine are being installed together.
  2. Cobot option is ordered so that it can be installed on a previously installed machine.
  3. Cobot option was previously installed on a machine, but will now be moved to a different Haas machine.
In scenarios 2 and 3, additional parts will need to be ordered under the Serial Number of the Haas machine. See the tables below for what parts are needed in the different scenarios.
Scenario 1 - Cobot and Machine are ordered and installed together
Component Part Number Description
NO ADDITIONAL PARTS NEED TO BE ORDERED WHEN COBOT AND MACHINE ARE ORDERED TOGETHER
Scenario 2 - Cobot being field installed on existing Haas Machine
CHECK TO SEE IF HAAS MACHINE ALREADY HAS THESE FEATURES & PARAMETERS BEFORE ORDERING
Robot Feature Unlock Parameter 93-1001031 Kit activates the robot feature on the Haas machine. To check if you need this kit, go to the Features tab on the Haas Control and check if the Robot option is highlighted. This kit does not include any physical parts.
Load Type Safety Parameters 93-1000997 Front Automation Safety Parameters - Kit is needed when the cobot will be loading parts through the front door of the Haas machine. This kit does not include any physical parts and the autodoor option would need to be purchased and installed separately.
OR
93-1000996 Side Automation Safetly Parameters - Kit is needed when the cobot will be loading parts through the side window of the Haas machine. This kit does not include any physical parts and the autowindow option would need to be purchased and installed separately.
Scenario 3 - Cobot is being transferred from one machine to a different Haas Machine
Cobot Integration Kit See Integration Kit Compatibility Chart Kit is needed to install parts on the Haas machine to interface with the cobot. This includes the interface box, door switches, etc... as well as the Robot Unlock Feature parameter. This kit only needs to be purchased when transferring a cobot to a new Haas machine since these parts are normally included when a cobot is ordered.
OR
Safety Device 08-1899 Multi-Sided Light Curtain Kit - Kit is needed if the safety device is NOT going to be transferred from the first machine and the second Haas machine needs it's own safety device. This kit makes a 4-sided protective barrier.
OR
08-1948 5-Sided Light Curtain Kit - Kit is needed when the safety device is NOT going to be transferred from the first machine machine and the second Haas machine needs it's own safety device. This kit makes a 5-sided protective barrier.
OR
08-1987 Laser Area Scanner Kit - Kit is needed when the safety device is NOT going to be transferred from the first machine machine and the second Haas machine needs it's own safety device. This area scanner has a sensing distance of 4meters.
Lathe Setup
Power OFF the machine.
Remove the auto door cover [1].
For machines with the switch bracket holes on the roof panel. Install the switch bracket to the right pair of holes[1].
For machines without the switch bracket holes on the roof panel. Use the provided drill guide [1] to drill the mounting holes for the DOOR FULLY OPEN status switch.
Align the right most hole on top of the drill guide that is marked with one slot [2] with the autodoor cover mounting hole to the left of the auto door motor and secure it with the BHCS.
ST-10/15:
  • Drill the two Ø 3/16" (4.7mm) mounting holes through the drill guide holes that are marked with one slot [3].
ST-20/25/28/30/35/40/45:
  • Drill the two Ø 3/16" (4.7mm) mounting holes through the drill guide holes that are marked with two slots on both sides [4].
Using the provided self tapping screws, install the DOOR FULLY OPEN switch assembly [5] and the DOOR FULLY OPEN trip flag [6].
Note: For longbed machines (ST-20L thru ST-35L), do this step for both the left and the right door.
Connect the DOOR FULLY OPEN switch as labeled:
  • BLK <COM> to the top terminal [1].
  • RED <NO> to the middle terminal [2].
Route the cable into the control cabinet as shown on the picture.
NOTE: Make sure to install the provided magnetic clip [3] and cable clamps [4] to keep the cable clear of the moving autodoor motor [5].
Connect the other end of the cable to the SIO PCB P27 RRI Door Open input.
Note: For Long Bed machines with 2 doors connect to PROX NO RIGHT DOOR FULLY OPEN to SIO PCB P72.
NOTE: Make sure the machine is turned OFF.
Install the autodoor cover.
  • The spring pusher is made with a shank to fit either a 25mm or 1” tool holder
  • This tool must take up a toolholder on the turret
  • If the machine is a ST-10/15 you will need two empty toolholders to allow enough space for the gripper
  • Program the following steps to the beginning of any  program to make sure the part is properly seated into the chuck:
    • Locate the spring pusher in front of the part
    • Move the Z axis to compress the spring about 0.50 inches or 12.7 mm
    • Open the chuck with a dwell of one second
    • Close the chuck with a dwell of one second
    • Retract the turret to the safest position possible
Note: The Part Number for the spring pusher is:
  • 30-12642 SPRING PUSHER.  The 25mm or 1.0” holder is sold separately.
Cobot Installation
Verify that the Cobot and its control box are from the same matching set with matching serial numbers.
There is a white decal with the Haas serial number [1]. Make sure these are the same on both boxes.
There is a yellow circle decal with an identification number [2]. Make sure these are the same on both boxes.
Measure these dimensions from the machine's skirt to the pedestal's side.
 Note: The following dimensions are recommended distances. The position may vary depending on the users application. For Cobot placement information, refer to the Cobot Machine Layout Drawing.
The Haas Cobot 30 is recommended to be paired with the HC30 Stand. This stand is configured to be sufficiently stable when used according to Haas defined part size and weight limits.
For ST-20 thru ST-45 Machines:
Position the pedestal and parts table in the following location relative to the machine:
Dimension Imperial (Inches) Metric (cm)
Front of machine to front side of pedestal [1] -- in -- cm
Left of machine to left side of pedestal [2] -- in -- cm
Front of machine to front side of parts table [3] -- in -- cm
Left of machine to left side of parts table [4] -- in -- cm
Anchor the pedestal into the ground. Level the pedestal using a bubble level.
 NOTE: For the adjustable pedestal, set the desired height by loosening the set screws [1] then adjusting the clevis pin [2]. Retighten the set screws [1] before installing the robot. Place a bubble level on the top of the pedestal while using the (x4) hex bolts at the base to set the level in the X & Y plane.
Place the Cobot control box [3] directly next to the pedestal to ensure enough slack for the cables.
Remove the Cobot from the shipping box.
 NOTE: Install the adapter plate between the pedestal and robot if needed.
Install the Cobot on top of the pedestal with (x6) screws.
NOTE: Make sure the cobot cable connector [1] is perpendicular with the front of the machine.
IMPORTANT: The Cobot is about 45 lbs and should be lifted with a device that can safely lift that weight.
Inside the Cobot packaging, there is a small bag [1] filled with spare parts including:
  • Fuse
  • Screws (x2)
  • Control Box Keys
There is a medium bag [2] filled with an extra M12 connector. This cable can be used to configure inputs and outputs for the End I/O Module.
There is a large size bag [3] filled with papers and a USB stick downloaded with the Cobot software.
Make sure to keep these spare parts somewhere safe for future use.
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Connect Interface Box to Haas Machine:
The robot safety devices interface box 32-9018 has magnetic mounts to attach to the machine sheet metal. Mount the interface box [1] as shown in the picture.
Route the interface electrical cables [2] along the enclosure with the magnetic mounts and zipties. Route the cable through the bottom of the electrical cabinet.
NOTE: For information on upgrading the interface box to the Robot Safety Devices Interface Box, refer to the Robot Safety Devices Interface Box - Installation - AD0703.
Connect Interface Box to Haas Control Cabinet:
Connect cable 33-8562C E-STOP terminal block to TB-1B [1] and connect the Setup mode terminal block to TB-3B [1] on the SIO PCB.
Plug the user relay into K9 and K10 [2].
Verify the jumper is installed on the SIO PCB at JP1.
Connect the pigtail cable labeled P1 SIO to the SIO PCB at P1 [3]
NOTE: If the machine has a Regen Vector Drive, unplug cable 33-0634 FILTER OV TO IOPCB P1 from P1 SIO and plug it into the connector FILTER OV FAULT on cable 33-8562C. If the machine does not have a Regen Vector Drive, do not plug anything into the connector FILTER OV FAULT.
Connect the RJ-45 cable [4] to Ethernet to USB adapter [5] (33-0636).  Connect the USB connector end to the Maincon PCB J8 top port. Add a ferrite filter [6] to the USB adapter.
Mount the 24VDC Power Supply [7] to the left side of the control cabinet and plug into connector labeled 24V PS on cable 33-8562C. Connect cable 33-1281 [8] to the 24VDC Power Supply [7] and plug into P3 on the PSUP PCB.
For MM/SMM CM/CL machines Without XMR
If P3 is occupied by a jumper connected from P3 [10] to P7 [9] on the PSUP PCB, a splitter cable is needed to allow the 24VDC power supply [7] to be connected to the 120VAC connectors on the PSUP. Connect the male connector of the splitter cable to P3 [10] and then connect the jumper from that cable to P7 [9] and also cable 33-1281 [8].
Note: Make sure that the jumper cable is connected where the red lines up with the red from the splitter cable.
Inside the Cobot control box, install part of the robot signals cable (33-1272 or 33-1351).  To do so, remove the safety connector [1] from the Cobot control box in order to install the different colored wires into their respective location
33-1272 / 33-1351 cables [2] going to safety connector:
  • Gray wire to top 24V
  • Red wire to bottom 24V
  • Green wire to EI0
  • Brown wire to EI1
  • Jumper [3] from SA0 to SA1
  • Jumper  [4] from SB0 to SB1
 NOTE: The rest of the wires from this cable are not used. Put some electrical tape on each wire lead and Ziptie the leftover unused wires.
Important: After installing all the cables from the robot signal cable, make sure that the fuse [1] remains installed at all times to protect the Cobot control box.
Connect Cobot to the Interface Box:
Connect the RJ45 ethernet cable [1] from the Cobot Control Box to the interface box. Add a ferrite filter [2] to the RJ-45 cable.
Connect the robot signals cable [3] from the Cobot Control Box to the interface box.
Connect the 120 VAC Cobot Power Cable [4] to the external power source.
Connect the robot power cable [5] from the control box to the Cobot.
Connect the teach pendant cable [6] from the control box to the teach pendant.
NOTE: For more information regarding interlock fence, area scanner or light curtain installation, refer to the Robot Safety Device section below.
Make sure the Remote Jog Handle is installed onto the machine.
NOTE: For more information on the RJH-XL installation, refer to Remote Job Handle - Touch Large (RJH-XL) - Installation - AD0533.
Steps 7 thru 10 are wiring and hose routing instructions for the pneumatic grippers. Refer to the grippers installation section lower on this page for the mechanical installation.
Install the dual air solenoid assembly on to the side of the pedestal while giving the airlines enough slack. Make sure it's in a position where it will not be in the way. Route the airline [1] under the machine back towards the CALM cabinet as shown.
Inside the CALM cabinet, remove a plug from one of the CALM manifold ports and install the check valve [1] (58-1863) onto the port's fitting. Route the input airline [2] from the dual air solenoid assembly (from previous step) into the CALM cabinet and connect the airline to the check valve.
Turn the machine air supply ON.
Make sure to power OFF the control box [1].
Connect the solenoid cable from the dual air solenoid assembly [2] into the Digital Output on the Cobot control box [1]. Remove the connector from Cobot control box.
Connect the gripper solenoid power cable (33-1276 / 33-1341) to the Digital Output terminal inside the control box. Install the different colored wires into their respective location:
  • Black/white cable into 0V
  • Black cable into DO0
  • Orange/white cable into 0V
  • Orange cable into DO1
  • Red/white cable into 0V
  • Red cable into DO2
  • Brown/white cable into 0V
  • Brown cable into DO3
Power ON the control box.
Robot Safety Device
IMPORTANT: DO NOT OPERATE THE ROBOT UNTIL YOU HAVE PROPERLY CONFIGURED AND TESTED THE OPERATION OF THE SAFETY DEVICE.
Light Curtain:
Cobot packages come with the light curtain emitter and reciever as the default safety device. Follow the procedure below for light curtain installation:
Light Curtain Installation
NOTE: If the area scanner or HC10 Machine Ready kit was ordered, there will also be a 1M light curtain receiver and emitter. These come with all Cobots.
Robot Fence:
If the machine came equipped with the fence option, the robot fence and door interlock assembly need to be installed to machine. Follow the procedure below for installation:
Robot Fence Installation
Once the fence is installed, next install the fence panel in between the machine and robot fence.
Area Scanner:
If the machine came equipped with the area scanner option, the area scanner needs to be installed and configured to the space. Follow the procedure below for installation:
Area Scanner Installation
First Power-UP
Power ON the Haas machine.
Power ON the Cobot by flipping the power switch [1].
Power ON the Cobot teach pendant by pressing the circle [2].
Make sure that E-STOP [3] on the Cobot teach pendant is released.
In order to change the language, click on the language drop down menu. Choose EN for English. To confirm this setting change, the Cobot teach pendant will have a popup asking to insert the username & password.
Enter "admin" for both the username and password.
Download and load the configuration files by logging into the HAAS SERVICE PORTAL.
Download the safety automation option front/side configuration files.
Load the option configuration patch file to the control. Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
Turn on the Haas CNC.
Zero Return all Axes.
Insert Service USB key.  Go into Service mode.
Go to Parameters> Factory tab.  Change the following:
  • 1278 [1278:] Robot Ready E-Stop Enabled to TRUE
  • 2191 [694:] LIGHT CUTAIN TYPE to LC_TYPE_1
  • 2194 [:] Enable Front Door Fully Open Switch to TRUE
Important: For machines with 2 front doors do not set 2194 to TRUE. Instead set 2195 Enable Left Door Fully Open and 2196 Enable Right Door Fully Open to TRUE.
Note: Machines with Software Version 100.20.000.1010 or higher will need to change the following parameter:
  • 2192 [:] Light Curtain Trigger Threshold to 0
Press [SETTING].
Set the Settings:
  • 372 Parts Loader Type to 3: Robot.
  • 376 Light Curtain Enabled to On
On the Haas pendant, press [CURRENT COMMANDS].
Go to Devices>Robot>Jogging tab. Change the following:
  • Maximum Jogging Speed to 7.9 inch/sec
Go to the Setup tab. Change the following:
  • Max Robot Speed to 118 in/sec (2000 mm/sec).
  • Enter the Net Mass of the gripper. Refer to the layout drawings on our website (Single Gripper layout drawing OR Dual Gripper layout drawing) to get the correct value for this setting
WARNING: Setting this value incorrectly can cause the Robot Arm to not move correctly.
  • Number of Grippers to the number of grippers.
  • Raw Gripper Clamp Output to 1.
  • Raw Gripper Unclamp Output to 2.
  • Raw Gripper Clamp Delay to the clamp/unclamp duration in sec.
  • Raw Gripper Clamp Type to OD/ID.
  • Finish Gripper Clamp Output to 3.
  • Finish Gripper Unclamp Output to 4.
  • Finish Gripper Clamp Delay to the clamp/unclamp duration in sec.
The Cobot teach pendant will have a popup asking to insert the username & password. Enter "admin" for both.
Go into Jog mode [1].
Move each joint to it's zero location with the Move Zero buttons [2].
Once the robot is in it's zero location, verify that the hash lines [3] align on either side of each joint on the Cobot.
Connect an ethernet cable [4] from the Cobot control box into a computer.
On the computer, change the adapter setting to enable the ethernet port.
To change the adapter settings, open the settings page [1] on the computer, then click on Network & Internet [2] which will bring up the network status page.
Click on Change adapter options [3] then right click on Ethernet [4] and open up the properties window [5]. From there select the Internet Protocol Version 4 (TCP/IPv4) [6] option and click Ok.
The ethernet settings will now be correct. Open a web browser window and type in the IP address of the cobot[1].
Note: This is the same process as connecting a laptop to an HRP-1/2/3. For more information on connecting to the cobot via ethernet, refer to the video on the HRP-Troubleshooting page that is in the Connect & Jog Haas Robot section.
Download HRTool through HBC. On the Service section of HBC, navigate to Utilites > Documents and Software > 01 Control Software > 01 Next Generation Control > 10 Cobot Software > HRTool.zip.
Unzip the folder and navigate to HRToolsMaind.exe.
Insert the Cobot IP address found under the Systems tab.  Click Set.
Go to the Config tab on HRTool.
Click "get" to see the actual vs. theoretical encoder values.
Click "set" to set the theoretical to the actual encoder values. This step sets the Cobot's current position as it's new home position.
Make sure that each joint's actual and theoretical encoder values match.
NOTE: If the valuyes do not match, press "Set" again.
Security Risk Level
IMPORTANT: Make sure to perform an appropriate risk-assessment and met all appropriate safety requirements.
Based off the risk assessment, set the appropriate security risk level on the Cobot teach pendant. Navigate to Config > General Restrictions and tap of the desired security risk level [1] from 0 - 5.
Use the  "admin" code in the safety verification to change the security level.
NOTE: When the security risk level is lower, the robot will have a lower maximum speed, force, etc. When the security risk level is higher, the robot will have a higher maximum speed, force, etc.
This security risk level will calculate the maximum allowable force, speed, power, momentum, elbow speed and elbow force [2] that the Cobot will withstand before Alarm 9150.10017 Collison Stop Error is triggered.
IMPORTANT: The robot's programmed speed cannot be greater than the allowable speed from the security risk level.
NOTE: For more information regarding alarms, refer to the Haas Cobot - Troubleshooting Guide.
Activation
Go to Parameters > Features > Robot to verify that the robot feature has appeared on the bottom.
Press [CURRENT COMMANDS].
Go to Devices>Robot>Setup tab [1].
Press [E-Stop].
Press [F1] to connect the robot[2].
The first time connecting a robot to a machine, the robot feature will need to be unlocked. This popup shows the machine's current software version, robot mac address and a generated code. Enter this information into HBC in order to receive the unlock code.
On HBC, go to the Service tab [1].
On the left hand side of the screen, click on Activations [2], and then select Cobot Installation [3] to begin the process to the get the Cobot unlock code.
The first step is to enter the Machine Serial Number [4] and the Cobot Serial Number [5] in the fields on HBC.
Once you have entered the correct information, press Next [6] in the bottom right corner and continue through the steps until you receive the unlock code.
Note: Make sure you are on the Cobot Installation tab [3] and not the Robot Installation tab. The Robot Installation is only used for the Haas Robot Packages. Using the Robot Installation for the Haas Cobots will result in an invalid unlock code.
Enter the Cobot's Haas Serial Number[1] and the unlock code to connect the robot to the machine.
 Note: This step can only be completed by a HFO Service Technician.
 Note: The machine needs to be activated before the Cobot is activated. Follow the Machine Activation / Time Extension - NGC procedure.
When the robot has connected with the machine, a yellow message saying Robot Activation Successful should appear at the bottom of the Haas screen.
Release the [E-STOP] and press RESET to clear the alarms.
Press the [HANDLE JOG] button.
Press the [CURRENT COMMANDS]  and go to Devices > Robot > Jogging tab.
 Note: The robot in setup mode can only be handle jogged while the F2 button the RJH is pressed. See Setup/Run mode section below.
On the Remote Handle Jog Touch press the Joint button to go into the Joints Coordinates.
Move the robot to an accessible location to install the grippers.
Jog J6 to 0.0000 position. The location hole should be centered on top.
Note: Press [E-STOP] before working on the robot.
Gripper Installation
Shut off the machine air by turning the valve in the Air/Lube cabinet and pull the pressure relief valve to release the air in the system.
For HC15 Dual Grippers (09-0726):
Jog the cobot so that you have access to install the grippers. Use the electrical connector on joint 6 of the arm [3] to properly align the dual gripper mounting plate [1].
The electrical connector [3] should be lined up in between the top two fasteners [4] with gripper 1 on the left and gripper 2 on the right as shown in the image.
Fasten the gripper's mounting plate [1] to the end of the cobot using the 7 SHCS [2].
Install the dual gripper assembly onto the mounting plate. Fasten the grippers to the mounting plate using the 8 SHCS [1] fasteners and washers as shown in the image.
Note: Make sure that the labels "1" and "2" on the gripper assembly [2] are lined up with the corresponding labels on the mounting plate.
For HC15 Single Grippers (09-0727):
Fasten the gripper's Mounting Plate [1] to the end of the cobot using the 7 SHCS [2] and washers. The alignment needs to be verified when installing the mounting plate.
To verify the alignment, make sure that the electrical connector [3] is lined up in between the 2 top mounting holes [4] as shown in the image.
Fasten the single gripper assembly [1] to the mounting bracket [3] using the 4 SHCS and washers [2]. Make sure that the gripper assembly is oriented so that the air hose fittings [4] are located toward the top of the mounting plate.
Configure the dual air solenoid assembly used for pneumatic grippers depending on single [1] or dual [2] gripper configuration.
For single grippers [1], connect the incoming air to the to the fitting [2] and keep the plug in the other end of the fitting [3] as shown in the image.
For dual grippers [4], remove the plug in the fitting [3] and attach a small air hose to the second solenoid [5]. Then connect the incoming air hose to the fitting [2] so that both solenoids are receiving air.
For the Single Gripper:
Route the (x2) air lines from the gripper to the same color coded fitting on the dual air solenoid assembly.
Secure the air lines by wrapping them in cable conduit. Use the velcro straps to attach the cable conduit to the cobot. Make sure there is enough slack so that cables aren't strained when cobot is fully extended.
Insert the input air hose to the used solenoid's fitting [1].
Make sure the plug is installed onto the unused solenoid's fitting [2].
For the Dual Gripper:
Route the (x2) air lines from gripper #1 to the same color coded fitting on the dual air solenoid assembly.
Route the (x2) air lines from gripper #2 to the same color coded fitting on the dual air solenoid assembly.
Insert the short airline [1] connecting the first solenoid with the second.
Insert the input air hose to the fitting [2].
If the parts table option was ordered, follow the procuedre below for assembly instructions:
Haas Robot - Parts Table Assembly
NOTE: If HC15 MACHINE READY KIT was purchased, there is no need to install the wheels if moutning the parts table directly into the wooden pallet.
Verification
Test the E-stop:
  • Press each E-STOP button located on the Haas Pendant, RJH-XL, and Cobot Teach Pendant. Make sure the machine generates 107 EMERGENCY STOP alarm.  If the E-STOP button does not generate a 107 EMERGENCY STOP alarm verify the wiring. Load the latest configuration files to enable the RJH-XL.
Test the Robot Safety Device:
Make sure that there is an E-STOP or light curtain triggered icon on the Haas pendant when the robot safety device is triggered.
  • Fence - Insert the key into the interlock, verify that the two red LED lights in the front of the interlock are OFF. Remove the key from the interlock, verify that the two red LED lights are ON.
  • Area Scanner - Step inside the protective field, verify that the red LED lights up on the area scanner. Step outside the protective field, verify that the green LED lights up.
  • Light Curtain - Interfere the light curtain beams, verify that the light curtain triggered icon appears on the Haas pendant. Press [RESET]. Step outside of the light curtain beams, verify no icon appears on the Haas pendant.
NOTE: If the light curtain triggered icon does not show, verify wiring, alignment and factory setting: 2191 [694:] LIGHT CURTAIN TYPE is set to LC_TYPE_1.
Test the Operation of the Grippers:
  • Verify that both grippers clamp and unclamp correctly.
  • Press the [CURRENT COMMANDS]  and go to Devices > Robot > Jogging tab.
  • Press [F2] to clamp/unclamp the Finish Gripper.
  • Press [F3] to clamp/unclamp the Raw Gripper.
Test the Remote Jog Handle:
  • Undock the Remote Jog Handle
  • Press the [HANDLE JOG] button.
  • On the Remote Handle Jog press the Joint button to go into the Joints Coordinates.
  • Move the robot to a safe location.
IMPORTANT: If a yellow warning message appears saying "Please activate Light Curtain or Cell Safe" while trying to job the robot, verify the safety parameter was applied by re-uploading the configuration files from HBC.
Verify Safe / Run Mode Operation
All Haas CNC machines are equipped with a key switch on the side of the control pendant to lock and unlock setup mode. The robot will have the following behaviors depending on what mode is selected.
  • When the Haas control is in Run mode, mode 1, triggering the robot safety device stops all motion. This motion can not be started until the robot safety device is no longer triggered.
  • When the Haas control is in Set up mode, mode 2, speed limited motion such as jogging an axis of the robot can be performed in order to program a robot's path of motion, pick up position, set a robot's tool center point, (an offset), load and pick up parts from the spindle or part holder in the machine, etc. The programmed path will also be able to be run slowly to prove out the programmed path of the robot. The robot in setup mode can only be handle jogged while the F2 button the RJH is pressed.
After installing the robot, set up a job following the procedure below.
Disable the Robot
To disable the robot to run the machine in stand-alone mode. Press [SETTING]. Change the following Settings:
  • 372 Parts Loader Type to 0: None
  • 376 Light Curtain Enabled to Off
