Lathe - Sub-Spindle Part Ejector - Installation - AD0626
Service Home How To Procedures Lathe - Sub-Spindle Part Ejector - Installation - AD0626
Recently Updated Last updated: 02/10/2025
Revision 1
AD0626
- Jump to Section - 1. Introduction 2. 5" Chuck Parts Ejector Installation (2 steps) 3. 6" Chuck Parts Ejector Installation (2 steps) 4. Chuck Parts Ejector Removal (1 step) Back to Top
Machine Compatibility:
The following installation instructions for the 5" Chuck Parts Ejector P/N 30-13460 can be installed on ST-10/15/20/25/28 and all variants.
The following installations instructions for the 6" Chuck Parts Ejector P/N 30-13459 can be used on ST30/35 and all variants, and DS-30Y built after Jan, 30 2024.
Service Kit Compatibility:
The following installation instructions can be used with service kits to rebuild the part ejectors:
  • 93-3505 PART EJECTOR 5" CHUCK GAS SPRING REBUILD
  • 93-3506 PART EJECTOR 6" CHUCK GAS SPRING REBUILD
For Service Kit P/N 93-3505:
Press internal o-ring [1] against inner diameter of the ejector body [2], install the two external o-rings [3] around the outer diameter of the ejector body.
Replace the gas spring [4] by pressing it into the ejector body firmly if body has a through hole OR by threading it into the ejector body if body has a tap hole.
Line the part ejector [1] up with the hole in the sub spindle, and press it in. The part ejector [1] will stop against an internal lip in the draw bar [2], press it in until movement stops.
Note: The sub spindle jaws may need to be unclamped or removed for installation of the Part Ejector.
For Service Kit P/N 93-3506:
Press internal o-ring [1] against inner diameter of the ejector body [2], install the two external o-rings [3] around the outer diameter of the body.
Unclamp the sub spindle jaws and pull out the part ejector.
 Note: The sub spindle jaws may need to be removed for removal of the Part Ejector.
If the gas spring [1] slides out alone leaving the ejector body [2] inside the sub spindle, use the hole [3] at the end of the ejector body for removal.
NOTE: Check the ejector body hole [3] to see whether it's a tapped or through hole. If through hole, use a #7 drill bit to create a 1/4-20 tapped hole at the bottom of the ejector body.
 WARNING: If a tapped hole is needed for the 6" chuck ejector, it's normal for the part ejector to stick out around 0.2" from the chuck jaws.
