Servo Motor Mount Cover - Replacement - AD0666
Service Home How To Procedures Servo Motor Mount Cover - Replacement
Recently Updated Last updated: 01/13/2026
AD0666
Revision A - 1/2026
- Jump to Section - 1. Introduction 2. Installation (3 steps) Back to Top
This procedure outlines how the install the molded servo motor mount covers. The motor mount covers will replace Peel and Seal Covers and used to replace any cover that may have been damaged.
Important: Refer to the VF/VR - X/Y Motor Mount Cover - Reference document to determine the compatible motor mount cover part numbers. Failing to install a motor mount cover on a compatible motor can result in coolant intrusion.
 Warning: Not all motor mounts have a compatible cover. Confirm that the motor mount part number matches the cover before ordering.
Note: The images in this document reflect the VF X-Axis motor mount cover, but the placement of the VHB tape is the same on all the covers.
Once the old cover is removed, clean the motor mount and cover with acetone on the areas colored in yellow.
Then attach the VHB tape to the motor cover as shown [1]&[2]. The 4.5 inch piece goes on the motor cover towards the middle and the 3.5 inch piece goes on the motor cover towards the front.
After the VHB tape is attached remove the plastic film so that the motor cover is ready to be attached to the motor mount [3].
Place the cover on the motor mount as shown.
Apply pressure to the cover to ensure the VHB tape bonds the motor mount and motor cover.
