ST-10/15 - External Live Tooling - Motor - Replacement - AD0176
Service Home How To Procedures ST-10/15 - External Live Tooling - Motor - Replacement
Recently Updated Last updated: 04/11/2023
AD0176
Applies to machines built from: March, 2015
- Jump to Section - 1. Motor Replacement 2. Safety Notes 3. Machine Compatibility 4. Replacement (4 steps) Back to Top
Motor Replacement
This procedure shows you how to replace the live tooling motor.
Safety Notes
Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
Do these steps before you do work in the machine or in the control cabinet:
  • Set the main circuit breaker to the OFF position.
  • Use an approved lock with an approved safety tag. Always follow lock-out procedures in accordance to local government rules.
  • After turning off the machine, wait at least 5 minutes before working in the control cabinet, to allow power to dissipate. Wait for the voltage indicator LED on the vector drive to go off completely.
  • Always turn off the main air supply when you work on any part of the pneumatic system.
  • Make sure to rest the spindle head on a block of wood when work is done on a vertical axis. This will prevent any unintended movement that could result in the axis falling.
  • Never alter any safety circuits on the machine.
  • Never change any parameter while in DEBUG mode (Classic Haas Control) and the servos ON. Put the machine in Emergency Stop mode to change any parameters.
  • Never operate the machine in DEBUG mode (Classic Haas Control).
You should not do machine repair or service procedures unless you are qualified and knowledgeable about the processes. Serious damage to the machine components can result in costly repairs. The service technicians at your Haas Factory Outlet (HFO) have the training and experience, and are certified to do these tasks safely and correctly. The repair and service work performed by your HFO is protected with a limited warranty.
Danger: Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
Do this procedure for these machines:
  • ST-10/20/25/30/35, DS-30 Series
Replacement
Push [POWER OFF].
Lock the main circuit breaker.
Remove the cover [1] from the motor [2] for the live tooling.
Disconnect the power and encoder cables [3] from the motor.
Remove the motor.
Do these steps to make the muffler-tube assembly:
  • Push the TUBE [B] into the MALE FITTING [A].
  • Push the other end of the TUBE into the FEMALE FITTING [E].
  • Connect the MUFFLER [D] to the FEMALE FITTING.
Install the muffler-tube assembly [2] onto the housing for the live tooling. Put the other end of the muffler-tube assembly into the lathe adjacent to the power and encoder cables [3].
Fully clean the mating surface [1] on the housing.
Apply white lithium grease to (1) side of the MOTOR GASKET [C].
Put the side of the gasket that has grease against the mating surface [1] on the housing.
Install the MOTOR ASSEMBLY [G] into the housing.
Install the (4) screws [4] to install the motor. Tighten the screws in a star pattern. Torque the screws to 25 ft lb (34 Nm).
Connect the power and encoder cables [3]. Use the CABLE TIES [F] to attach the cables to the muffler-hose assembly.
Install the cover for the motor.
Do a test of the live tooling for the correct operation.
