Standard Coolant - Universal - 14’ Hose - Replacement - AD0220
Service Home How To Procedures Standard Coolant - Universal - 14’ Hose - Replacement - AD0220
Recently Updated Last updated: 02/08/2022
Standard Coolant – Universal - 14’ Hose - Replacement
AD0220
Applies to machines built from: January, 1989
- Jump to Section - 1. Introduction 2. Replacement (2 steps) Back to Top
The Flood Coolant 14' Universal Replacement Hose is a universal kit. Not all of the parts will be used.
  • This kit contains all of the parts necessary to replace the low-pressure supply hose on a Haas CNC machine.
  • The hose in this kit replaces the 5/8" or 3/4" flood coolant, factory-crimped hose on your machine.
  • The clamp-style hose fittings make a tighter connection that prevents leakage.
  • The nylon braided hose is durable, providing years of standard use.
KIT PN: 93-2335, HOSE, COOLANT 5/8 ID X 14 FT UNIVERSAL KIT QTY: 1
[A] 58-1841     14' (4.3 m)  HOSE 5/8 ID PU NYLON BRAIDED
[B] 28-0314    QTY: 7 FITG HOSE CAP 13/16 OD HOSE
[C] 59-1524    QTY: 7 CLAMP, HOSE EAR 21.3 - 24.1MM
[D] 58-1034    QTY: 2 FITG HOSE BARB-5/8 X 3/4GH-F
[E] 58-1843    QTY: 2  FITG HOSE BARB-5/8 X NPT-3/4-M
[F] 58-1845    QTY: 1  FITG HOSE BARB-5/8 X GH-3/4-M
[G] 58-2061    QTY: 2 FITTING, HOSE BARB5/8 NPT1/2M STR BRASS
[H] 58-1711    QTY: 1  FITG NPT3/4F NPT3/4F STR BRASS
Tools Required
  • Clamp Pliers
  • Hose cutter
Replacement
Prepare the new hose:
  • Remove the old coolant hose from the machine.
  • Cut the new coolant hose to the same length as the old hose.
Select new fittings:
  • Remove the old fittings from the machine, if applicable.
  • Match the fittings from the old hose and the machine, if applicable, to the fittings in the kit.
Install the new BARB FITTING [D, E, F, or G] onto the machine.
Put a HOSE CAP [A] over the barb of the fitting.
Put a CLAMP [B] over the end of the new HOSE [C]. Push the new hose fully onto the fitting.
Put the CLAMP [B] back over the barb section of the fitting 1/4" - 3/8" (6-10 mm) from the cap.
Use clamp pliers [5] to tighten the clamp around the hose.
Do this again on the other end of the hose.
Operate the coolant system at full pressure. Look for leaks.
