MCD Relay PCB - Replacement - AD0424
Service Home How To Procedures MCD Relay PCB - Replacement - AD0424
Recently Updated Last updated: 06/08/2022
AD0424
- Jump to Section - 1. Electrical Safety 2. MCD Relay PCB - Replacement (1 step) Back to Top
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
This procedure shows you how to replace the MCD Relay PCB.
Note: This PCB is also used to control a chain style SMTC, the steady rest, and the APL. In this procedure we will refer to this PCB as MCD Relay PCB.
This procedure applies to these parts:
  • P/N 93-32-3087C: SVC KIT SMTC MCODE RELAY TRIAC
[POWER OFF] the machine.
Put an identification label on each cable that is attached to the MCD Relay PCB. This makes the installation easier. Disconnect these cables.
Mark and remove all the cables from the
Remove the MCD Relay PCB from the hinge door.
Install the MCD Relay PCB [1].
Use your identification labels to connect the cables.
