Tailstock Home Switch Retrofit - Installation - AD0569
Service Home How To Procedures Tailstock Home Switch Retrofit - Installation - AD0569
Recently Updated Last updated: 03/01/2024
AD0569
- Jump to Section - 1. Introduction 2. Switch Removal (1 step) 3. Switch Install (3 steps) Back to Top
This retrofit kit is used to replace and relocate the tailstock home switch due to chips intrusion.
This document applies to the following service kit:
  • PN: 93-3393 TAILSTOCK HOMESWITCH RETROFIT ST-20/30/Y/L
Important : This kit does not contain the home switch cable,  the existing cable will be re-used.
Machine Compatibility
  • ACME Screw Tailstock Machines with roller type switches.
  • ST-20/25/28 machines built with 20-7462E BASE ST-20 MACH from 07/08/2021 to 09/16/2021.
  • ST-30/35 machines built with 20-7625D BASE ST-30 MACH from 12/01/2020 to 08/17/2021.
Switch Removal
1. Remove the ballscrew cover by removing the hardware bolting it.
2. Remove the flag from the tailstock, by removing the hardware bolting it to the ballnut housing.
3. Remove the switch housing by removing the hardware shown in the image.
4. With the housing removed the bolts that bolt down the old switch bracket are exposed and can be removed.
Switch Install
Replace the old switch flag [1] with the new switch flag [2] using the same hardware.
Installl the new roller switch to the new switch bracket and install the switch assembly in the same location as the old switch assembly.
1. Re-install the switch housing.
2. Re-install the ballscrew cover
Perform the AXIS GRID OFFSET - NGC procedure for the B-Axis after installing the switch assembly.
