TRT Pneumatic Vise - Installation - AD0525
Service Home How To Procedures TRT Pneumatic Vise - Installation - AD0525
7.4 TRT Pneumatic Vise - Installation
Recently Updated Last updated: 02/19/2021
AD0525
This procedure outlines how to install the TRT Pneumatic Vise.
Minimum Requirements:
  • Make sure the TRT Air Clamp Provision [1] is installed before performing this procedure.  Refer to TRT Rotary Air Clamp Provision - Installation procedure.
Remove the port plugs [1].
Install the 2-013 o-rings [2].
Note: If the vise is ever removed, plug the ports with 1/8 npt plugs to prevent contamination of the air system.
Verify the orientation of the vise ports [1] and the union ports [2] line up with each other.
Note:  The vise has two ports with different holes to ease with identification.  It is important to have proper orientation for correct clamp/unclamp action.
Install the vise bolts [1] and torque them to 60 ft-lbs or 80 N-m.
Manual Air Clamp Provision - Verification
Perform this step if you have the Manual - Air Clamp Provision.
Toggle the air switch and make sure the vise actuates correctly.
Note: The AUX 1 port will act as clamp and the AUX 2 port will act as unclamp.
Automatic Air Clamp Provision - Verification
Perform these steps if you have the Automatic - Air Clamp Provision.
Press SETTING and set Setting 276 Workholding Input Monitor to 15.
The clamp force of the Pneumatic Vise can be adjusted by adjusting the Air Regulator[1] on the Clamp/Unclamp solenoid. The higher the pressure, the greater the clamp force.
Verify the pressure switch functions by running the spindle in MDI: M03 S100;
Lower the air pressure all the way by turning down the regulator until the machine alarms with Alarm 180 Fixture Not Clamped. Adjust the pressure back to the desired pressure.
Press [CURRENT COMMANDS] and navigate to Devices > Workholding > Vise 1.
Press [ALTER] to setup the vise.
Press [E-Stop] and select 3. Custom Pneumatic Vise.
Press [ALTER] to go back to the vises view.
Press [F2] to clamp/unclamp the vise, make sure the vise actuates correctly.
