UMC-400 4th/5th Axis Cable - Replacement - AD0866
Service Home How To Procedures UMC-400 4th/5th Axis Cable - Replacement - AD0866
13.2 UMC-400 4/5th Axis Cable Replacement
Recently Updated Last updated: 05/01/2025
AD0866
Revision A - 05/2025
This procedure will explain how to replace the 4th and 5th axis cables for UMC-400s built before 04/2025 to move the axis cable connection from the side of the control cabinet to inside the electrical cabinet.
This procedure applies for the following kits:
93-5069 - 4/5AX PWR/ENC/BRK INSIDE CNTRL CONV KIT
Cable Replacement
Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
Disconnect the rotary cables (32-2984B and 32-1996C)  from the outside of the electrical cabinet and reroute the cables to the bottom of the electrical cabinet [1].
Remove the 4th and 5th axis power and encoder cables from the inside left wall of the electrical cabinet. Use the provided plugs [2] to cover the holes in the electrical cabinet.
Remove the encoder cables from Channel 4 and Channel 5 of the Maincon board. Remove the power cables from the 4th and 5th axis amps as well as the rotary brake pigtails from P16 and P17 on the I/O board.
Connect the power cable from (cable 32-1934) 4TH AXIS SRVOMTR/ENC/BRK CNTL EXT, and (cable 32-1935) 5TH AXIS SRVOMTR/ENC/BRK CNTL EXT to their respective amps.
Connect the brake pigtail from (cable 32-1934) to P16 [1]on the I/O board and the brake pigtail from (cable 32-1935) to P17 [2] on the I/O board.
Connect the encoder cable from (cable 32-1934) to Channel 4 [3] on the Maincon board and (cable 32-1935) to Channel 5 [4] on the Maincon board.
Connect (cable 32-2984B) [5] CBL ROT SIG.-5 W/S JBOX+PROX HM SW 9.5 to (cable 32-1934) 4TH AXIS SRVOMTR/ENC/BRK CNTL EXT
Connect (cable 32-1996C) [6] CBL RTRY SIGMA5+PRESS SW+M12 HM SW 9.5'to (cable 32-1935) 5TH AXIS SRVOMTR/ENC/BRK CNTL EXT
