VF/VM - Cable Retainer - Replacement - AD0792
Service Home How To Procedures VF/VM - Cable Retainer - Replacement - AD0792
Recently Updated Last updated: 07/30/2024
AD0792
- Jump to Section - 1. Introduction 2. Replacement (6 steps) Back to Top
This procedure tells you how to replace the cable retainer in the saddle of a VF/VM machine. This updated part helps relieve strain on cables coming from the bottom casting to the X- axis.
This document applies to these parts:
93-4753 - CABLE STRAIN RELIEF
Tools Required:
  • Flathead Screwdriver
  • Hexhead Screwdriver
  • Cutters
  • Leather Gloves
  • Rubber Mallet
Replacement
Send machine to HOME position [ZERO RETURN + ALL]
Caution: Make sure there is nothing in the way such as a long tool in the spindle that could cause a crash before doing so.
Push [POWER OFF].
Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Remove the screws [1] holding the right way cover for the X-axis.
Deattach the right sided X-axis way cover [1] from from the table and collapse partially to expose the internal components. Locate the original cable retainer [2].
 Caution: The way cover has sharp edges. Use the leather gloves when you handle the way cover.
Remove the screws [2] for the orginal cable retainer [2]. Once the screws are removed, slide the cable retainer up the cables out of the casting. Spread the orginal retainer from the center to remove the cables from the orginal piece.
Install the first half of the new cable retainer [1] to the casting using screws [2]. Gather the cables nicely into the slot of the first piece, then attach the second half of the new cable retainer [3] to the casting.
 Caution: Check to make sure none of the cables are being pinched on the sides when installing.
Reattach the right side X-axis waycover to the table.
If the way-cover is leaky or allows coolant to get to the internal componets, refer to VMC - Way Cover Wiper - Replacement
