VMC Z-Axis Waycover Installation - AD0585
Service Home How To Procedures VMC Z-Axis Waycover Installation - AD0585
Recently Updated Last updated: 03/24/2025
VMC - Z-Axis Waycover - Installation
AD0585
- Jump to Section - 1. VMC Z Axis Waycover Installation (3 steps) Back to Top
This procedure tells you how to install the Z-Axis cover on vertical Machines.
  • 93-1906: WAYCOVER, Z-AXIS VF0/1/2
  • 93-4462: WAYCOVER Z-AXIS SVC KIT MED VF
  • 93-2299: WAYCVR BELLOW Z AXIS LRG VF
NOTE: Machines built from 10/2010 to 09/2012 with the aluminum block Y-Axis washdown will need the 93-30-9170: Washdown kit.
Push [POWER OFF]. Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
If your machine has a Y-Axis washdown coolant nozzle [1], remove it.
Remove the screws from the top [2] of the waycover. Hold the waycover to lower it slowly.
Note: The chip guards [6] and the mounting rails [5] may not be symmetric depending on model. Verify the correct orientation before removing.
Remove the components in this sequence:
  • The Screws from the bottom [3] of the waycover
  • One of the mounting rails of the waycover[4]
  • The waycover [5]
  • The second mounting rail
Replace the (2) chip guards[6]. These are on the left and right sides of the spindle [7].
For VF Medium Machines:
New waycover 25-3678D has redesigned rails that mount with different screws, when it is being installed on a machine that previously had PN 25-3678C then the chip guards (PN 25-9041A or 25-14764) will need to be removed and discarded.
The new rails on PN 25-3678D will also use hole plugs now to plug the access holes.
Install (1) of the mounting rails [1].
Put the new waycover [2] into the bottom of the rail.
Caution: Make sure the mounting rail [3] goes in the space [4] of each waycover leaf.
Install the second mounting rail. Make sure the mounting rail fits into the space [4] of each waycover leaf.
Note: The waycover [2] should be installed so that the front of the waycover leaves are sitting on top of the mounting rails [1].
Install the Z-Axis cover plate [5]. Do this for machines that do not have a Y-Axis washdown coolant nozzle.
Lift the waycover [2] up to the bottom head cover [3]. Attach the top [1] of the waycover to the bottom head cover [3]. Use the (3) screws [4] that were in the bottom head cover [3] from the removed way cover assembly.
If you removed the Y-Axis washdown coolant nozzle, install it.
