Chuck and Tailstock - Recommended Maximum Pressure - RD0016
Service Home Chuck and Tailstock - Recommended Maximum Pressure - RD0016
Recently Updated Last updated: 10/16/2025
RD0016
This document shows the maximum recommended pressures for the SL and ST chucks and tailstock. Do not increase the pressure higher than what is recommended in the below tables.
The first table covers machines up to 04/2019.
The second table covers re-boot ST-20/25/30/35 machines built with a short body hydraulic cylinder. ST-20 and ST-25 all machines built 04/2019 to present.  ST-30 and ST-35 from 10/2019. ST30L from 11/2019.
Machines Built Prior to 04/2019
Type PSI Bar
5" Chuck 330 23
6" Chuck 330 23
8" Chuck, 2" Bore 330 23
8" Chuck, 2.5" Bore 260 18
10" Chuck 330 23
12" Chuck, 3" Bore 400 28
12" Chuck, 4" Bore 250 17
15" Chuck 340 23
18" Chuck 300 21
Tailstock 400 28
ST-20/25 Machines Built After 04/2019; ST-30/35 Machines Built After 10/2019
Type PSI Bar
6" Chuck 330 23
8" Chuck, 2.5" Bore 300 21
10" Chuck, 2.5" Bore 400 28
10" Chuck, 3" Bore 330 23
12" Chuck, 4" Bore 330 23
15" 440 31
18" 300 21
Tailstock 400 28
To adjust the pressure, turn the adjustment knob. The lathe can have two adjustment knobs. One knob is for the primary chuck. The other knob is for a tailstock or secondary chuck.
These differences change the recommended maximum pressure between 300-400 psi:
  • different type of chuck
  • different bar stock material
