Door Rules - Run / Setup Mode - RD0020
Service Home Door Rules - Run / Setup Mode - RD0020
Recently Updated Last updated: 10/16/2025
RD0020
- Jump to Section - 1. Run/Setup Mode Restrictions 2. Lathe - Run/Setup Mode Restrictions Back to Top
All Haas CNC machines are equipped with locks on the operator doors and a key switch on the side of the control pendant to lock and unlock setup mode. Generally, setup mode status (locked or unlocked) affects how the machine operates when the doors are opened.
Setup mode should be locked out (the keyswitch in the vertical, locked position) at most times. In Run and in Setup mode, the enclosure doors are locked closed during CNC program execution, spindle rotation or axis movement. The doors automatically unlock when the machine is not in cycle. Many machine functions are unavailable with the door open.
When unlocked, setup mode allows a skilled machinist more access to the machine to set up jobs. In this mode, machine behavior is dependent on whether the doors are opened or closed. The following charts summarize the modes and allowed functions.
Note: All these conditions follow assuming that the door is open and stays open before, during and the actions occur.
Danger: Do not attempt to override safety features. Doing so makes the machine unsafe and voids the warranty.
Machine Function RUN Mode SETUP Mode
Air Blast (AAG) On Not allowed. Not allowed.
Axis Jog using the Pendant Handle Jog Not allowed. Allowed.
Axis Jog using the RJH Handle Jog Not allowed. Allowed.
Axis Jog using the RJH shuttle knob Not allowed. Not allowed.
Axis Rapid using Home G28 or Second Home Not allowed. Not allowed.
Axis Zero Return Not allowed. Not allowed.
Automatic Pallet Change Not allowed. Not allowed.
APC Operation Buttons Not allowed. Not allowed.
Chip Conveyor CHIP FWD, REV Not allowed. Not allowed.
COOLANT button on pendant Not allowed. Allowed.
COOLANT button on RJH. Not allowed. Allowed.
Move Programmable Coolant Spigot Not allowed. Allowed.
Orient Spindle Not allowed. Not allowed.
Run a program, CYCLE START button on the pendant Not allowed. Not allowed.
Run a program CYCLE START button on the RJH Not allowed. Not allowed.
Run a program (Pallet) Not allowed. Not allowed.
Spindle FWD / REV button on the pendant Not allowed. Not allowed.
Spindle FWD / REV on the RJH Not allowed. Not allowed.
Tool Change ATC FWD / ATC REV. Not allowed. Not allowed.
Tool Release from Spindle Allowed. Allowed.
Through Spindle Coolant (TSC) On Not allowed. Not allowed.
Tool Air Blast (TAB) On Not allowed. Not allowed.
Advance, Retract, Rapid Tailstock Motion Not allowed. Not allowed.
Air Blast On Not allowed. Not allowed.
Axis Jog using E-Handwheel Jogging Not allowed. Allowed.
Axis Feed using E-Handwheel Rocker Switches Not allowed. Not allowed.
Axis Rapid using E-Handwheel Rocker Switches Not allowed. Not allowed.
Bar Feeder Set-up actions Not allowed. Not allowed.
Bar Pusher Set-up actions Not allowed. Not allowed.
Chip Conveyor CHIP FWD / REV Not allowed. Not allowed.
Chuck Clamp and Unclamp Allowed Allowed
COOLANT button on the pendant Not allowed. Allowed.
COOLANT button on the RJH. Not allowed. Allowed.
C-Axis Disengaged Allowed Allowed
C-Axis Engaged Not allowed. Not allowed.
High Pressure Coolant (HPC) On Not allowed. Not allowed.
Jog the Spindle Not allowed. Not allowed.
Previous Tool (RJH) Not allowed. Not allowed.
Retract, Extend Parts Catcher Not allowed. Not allowed.
Retract, Extend Probe Arm Not allowed. Not allowed.
Spindle FWD / REV button on the pendant. Not allowed. Not allowed.
Spindle FWD / REV on the RJH. Not allowed. Not allowed.
Tool Change ATC FWD] / ATC REV. Not allowed. Not allowed.
