HSK Required Maintenance - RD0022
Service Home HSK Required Maintenance - RD0022
Recently Updated Last updated: 10/16/2025
HSK Spindle - Required Maintenance
RD0022
- Jump to Section - 1. Required Maintenance Back to Top
WEEKLY:
  • Check the packing ring (lip seal) for wear
  • Check the gripper for damage, dirt, and for sufficient grease
  Note: HSK-A100 spindles should be re-greased monthly.
  • Re-grease all edges of the clamping cone and gripper segments that contact each other
  •   Note: Do not mix grease (the spindle was assembled using METAFLUX grease: Metaflux paste 70-8508 or Metaflux spray 70.82 are acceptable). METAFLUX  product is not available from Haas Automation and can be purchased off-the-shelf
    •  If the unit is very dirty remove the clamping unit and clean thoroughly
    • Do not spray compressed air into the spindle clamping unit - it will blow out all the grease
    • Always leave a protective tool holder in the spindle that does not have through-holes to prevent contamination of the clamping unit
  • Perform approximately ten tool changes to distribute the grease evenly.
  • Remove the tool holder from the spindle and, with a clean cloth, remove any lumps of visible grease.
6 MONTHS OR 200,000 TOOL CHANGES:
  • Measure the push-out in the unclamped position (10.5 mm +/- 0.1 mm; 0.41 in +/- .004 in)
    • Re-torque the locking screw through a clamped tool if you needed to adjust the push-out
  • Test clamp force (pull force):
    • HSK-A63: 2,835 - 4,050 lbs
    • HSK-F63: 1,730 -  2,472  lbs
    • HSK-A100: 10,116 - 13,038 lbs
    • If clamp force is not met you may need to re-grease the clamping unit, replace broken gripper segments, or replace a worn drawbar. Troubleshoot accordingly.
WHEN DAMAGED:
  • Replace the packing ring (lip seal)
    • It's not necessary to remove the bronze bushing to replace the seal, use pliers to grip the seal
