Spindle Vibration - Tolerances - Mill - RD0071
Service Home Spindle Vibration - Tolerances - Mill - RD0071
- Jump to Section - 1. Introduction 2. Tolerances for 30T, 40T, and 50T Spindles with a Max Speed of 20,000 RPM and below: 3. Tolerances for 20T & 30T Spindles with a Max Speed of 30,000-50,000 RPM 4. Use the following CPM ranges for Displacement Plots: 5. Use the following CPM ranges for Velocity Plots: 6. Displacement Example Plot: 7. Velocity Example Plots: Back to Top
Recently Updated Last updated: 05/05/2026
Mill - Spindle Vibration - Tolerances
RD0071
Revision B - 05/2026
This document contains the Displacement and Velocity vibration tolerances for mill spindles. Refer to the following procedures for how to run a vibration analysis test:
  1. Vibration Analysis - RS-232 Interface
  2. Vibration Analysis - Ethernet Interface
  • Displacement Tolerance:
    • Not to exceed 0.100 MIL at max speed
    •  Note: For 15K spindles, at 8K and 15K CPM the spike must not be more than 0.100 MIL
    •  Note: For 18K spindles, at 9K and 18K CPM the spike must not be more than 0.100 MIL
    •  Note: For GR machines, the spike at the maximum spindle speed must not be more than 0.200 MIL
    • Note: For DC machines, the spike at maximum spindle speed must not be more than 0.030 MIL
 NOTE: If the spindle does not meet the specified displacement tolerance, it should be rebalanced. For instructions on how to balance the spindle, refer to: Spindle - Balance Instructions - AD0547
  • Velocity Tolerances:
    • Not to exceed a total of (3) spikes between 30k and 210k cpm that exceed 0.005 in/s.
Updated
    • Not to exceed 0.040 MIL at max speed
    • Spikes must not exceed the following:
      • 0.060 in/s at maximum spindle speed.
        • Example: For a 30,000 RPM spindle running at max RPM, the tolerance at 30K CPM is 0.060 in/s.
      • 0.020 in/s at twice the maximum spindle speed.
        • Example: For a 50,000 RPM spindle running at max RPM, the tolerance at 100K CPM is 0.020 in/s.
      • 0.010 in/s at any other whole integer multiple of the spindle speed, 90K, 120K, 150K CPM, etc.
      • (3) spikes between 30K and 210K CPM that exceed 0.005 in/s
RS-232 Interface Ethernet Interface
0 - 33,000 CPM 0 - 38,452 CPM
30,000 - 93,000 CPM 38,452 - 76,904 CPM
90,000 - 153,000 CPM 76,904 - 115,356 CPM
150,000 - 213,000 CPM 115,356 - 153,809 CPM
- 153,809 - 192,261 CPM
- 192,261 - 230,713 CPM
Look at the spike at the maximum RPM.
In this case the spike is under 0.100 MIL
The spindle passes the vibration displacement test.
CPM Displacement Graph
15K Spindle - Vibration Displacement graph, 0-33000 CPM
In this case there are only two spikes that are over 0.005 in/s between 30K and 210K CPM.
The spindle passes the vibration velocity test.
CPM Velocity Graph
15K Spindle - Vibration Velocity graph, 0-33000 CPM
15K Spindle - Vibration Velocity graph, 30000-93000 CPM
15K Spindle - Vibration Velocity graph, 90000-153000 CPM
15K Spindle - Vibration Velocity graph, 150000-213000 CPM
