Axis Humming - Troubleshooting Guide - TG0032
Service Home Axis Humming - Troubleshooting Guide - TG0032
Recently Updated Last updated: 10/17/2025
TG0032
- Jump to Cause - 1. Introduction 2. Reference Graphs - Servo Motor Current Data Collection / Axis Load Test (5 steps) Back to Top
Axis humming can be caused by various reasons.
This guide will serve as a reference on how to fix axis humming issues.
NOTE: TO RECEIVE THE CORRECT TECHNICAL SUPPORT FOR HUMMING/NOISE ISSUES, IT IS REQUIRED TO PROVIDE A VIDEO OF THE SITUATION WITH AUDIBLE SOUND.
Symptom Probable Cause Corrective Action
Axis Humming Various reasons
Conduct and provide the following information to Haas Service:
  1. What axis is humming?
  2. Picture of the ballscrew wiper and check to see of there is a serial number on the end of the ball screw. If there is a serial number, take a picture of it and include it as well.
  3. Wipe the ballscrew, report the color of the lubrication, and look for any debris in the lubrication. Include a picture of the wipe.
  4. Is there any visible damage on the ballscrew?
  5. Provide an audible video of the humming.
  6. Provide a detailed description of when and where the humming occurs. (Ex: When in motion? When stationary? After being stationary for a period of time? Specifically, where is the humming happening? Ex: Travel at the motor end, middle, or support end?)
  7. Complete the Ballbar Test.
  8. Linear Axis Test: Resonance Scan Test & Axis Load Test
  9. Error Report
To load and run the Servo Motor Current Data Collection Program please refer to the Diagnostic Data Collection - Instruction procedure for further information.
Open the file with Excel.
Column A contains axis positions in MM.
Column B contains the current level of the desired axis.
Graph the current level (column B) on the Y-axis  and the distance traveled (column A) on the X-axis .
Ignore first few MM of motion as it shows spike in current due to acceleration.
There will also be a flat line at the end of the graph because the axis motion has stopped, but the data collection program kept saving the data. You can trim this out along with the last few MM of travel.
Typically this is what is considered a good graph and what to aim for when correcting any noise/humming.
Example 1:
In this example a machine was reported to have X-axis humming noise at full travel.
This graph shows that the current is rapidly spiking downward as it approaches the support end of travel.
NOTE: Make sure to take note of where the program starts to correctly adjust any misalignment.
In this case the support end centerline was 0.005 in below the motor end centerline. Shimming the support end to be inline with the motor end solved this example.
Example 2:
In this example a machine was reported to have out of spec torque readings and a humming noise in the X-axis.
From the diagram it was determined that a bind was present at both ends of the ballscrew.
In this example a saddle was machined out of spec, moving the centerline below the ballnut housing.
Example 3:
In this example a humming noise in the Z-axis was reported near max travel.
The heavy oscilllation near the support housing side shows that the support side was not inline with the motor side.
Shimming the support end gets rid of the humming noise.
