CL-1 Bar Pusher - Troubleshooting Guide - TG0046
Service Home CL-1 Bar Pusher - Troubleshooting Guide - TG0046
Recently Updated Last updated: 10/10/2025
TG0046
Jump to Section 1. Introduction 2. Symptom Table 3. EOB Airway 4. Pneumatic Diagram Back to Top
Bar Pusher
  • 1. Pusher In-Position Switch
  • 2. EOB Sensor
  • 3. Pusher Tube Air Supply Line
  • 4. Pusher Tube Strut
  • 5. Air Pressure Gauge
  • 6. Pusher Air Regulator
  • 7. Piston Feed Switch
How it Works - CL-1 Bar Pusher
Bar pusher vibration. Excessive spindle speed. Reduce spindle speed to 3,000 RPM or less. Larger bar stock is more susceptible to vibrations at speed.
Bar stock chamfer not centered. Center chamfer both ends of the bar stock.
Bar pusher support collars are worn. Replace worn out support collars.
G105 bar pusher air option is off when it should be on. Maintain air pressure with G105 Option Air "Yes" on the setup page.
Bar pusher air pressure too high or too low. Adjust Bar pusher air pressure to meet bar stock size. Larger bars 15-20 psi, smaller bars 10-15 psi.
EOB sensor not detecting the end of bar. Debri clogging EOB airway. Remove the end of bar sensor and bar pusher piston. Use compressed air to blow out the obstruction.
Pusher not advancing. Lack of lubrication. Remove the piston, clean and lubricate with a thin layer of grease. Check for moisture in the compressed air supply.
EOB Airway
Remove the plug [2] from the EOB sensor [1] mounting block.
A small orifice in the pusher tube [3] allows air pressure to trigger the EOB sensor.
Use compressed air to blow out any debris.
Pneumatic Diagram
