HRT310SS-BM
  1. Rotaries & Indexers
  2. Rotary Tables
  3. HRT310SS-BM
HRT310SS-BM
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
310 mm High-Speed Rotary Table
This version of our HRT310SS Super Speed rotary table is specially designed to mount on its back to provide high-speed C-axis positioning. The rotary uses a heavy-duty cycloidal drive system to provide a maximum indexing speed of 240° per second – more than three times the speed of our standard HRT310. The unit’s compact size and high speed make it the perfect complement to our VF-3SS and other high-speed Haas machines.
NOTE: Requires a Haas mill with 4th-axis drive and NGC software version 100.21.000.1130 or later for full 4th-axis operation. Stand-alone operation requires a Haas rotary control box shipped after November 10, 2021, with software version 26.38 or newer.
ATTENTION! Not compatible with CHC machines, due to cycloidal gear drive. Not intended for continuous platter rotation.
  • Modified to mount horizontally
  • Add 4-axis capabilities to your machine
  • High-speed 240°/sec indexing
  • Heavy-duty cycloidal drive system
  • Easy plug-and-play connection to Haas machines
  • Industry-leading performance and capabilities
  • 1 Spindles
  • 310 mm Platter Size
  • 400 ft-lb Max Torque
  • 240 °/sec Max Speed
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Compare Machines
BUILD & PRICE
Contact Distributor
  • Build-&-Price
  • Specs
  • Machine Info
  • Rotary Fit chart
Platter S.A.E METRIC
Platter Diameter 12.20 in 310 mm
Max Weight on Platter 435 lb 197.3 kg
Number of Std T-Slots 6 @ 60° 6 @ 60°
Spindle S.A.E METRIC
Max Speed 240 °/sec 240 °/sec
Torque (Continuous) 400 ft-lbf 542 Nm
Runout Max 0.0010 in 0.025 mm
Pilot Bore Diameter 3.2500 in 82.550 mm
Through-Bore Diameter 2.3250 in 59.055 mm
Backlash 30 arc-sec 30 arc-sec
Brake Torque @ 100 psi/6.9 bar 940 ft-lbf 1270 Nm
Gear Ratio 36.75:1 36.75:1
Timing 2:1  2:1
Indexing S.A.E METRIC
Accuracy (±) ± 30.0 arc-sec ± 30.0 arc-sec
Repeatability 10 arc-sec 10 arc-sec
Resolution 0.001 ° 0.001 °
Max Rotation/Step (with rotary control) 999.999 ° 999.999 °
General S.A.E METRIC
Power Requirement 115 VAC ±10% @ 15 A 115 VAC ±10% @ 15 A
Operating Temp (max ambient) 100 °F 38 °C
Air Pressure Max 150 psi 10.3 bar
Weight S.A.E METRIC
Table 415 lb 188.2 kg
Export Pallet 25.5 in x 27.5 in x 26.0 in 65 cm x 70 cm x 66 cm
Weight 440 lb 200.0 kg
AVAILABLE OPTIONS
DOCUMENTS
VIDEOS
RELATED PRODUCTS
Standard Features
  • Direct Control by Mill CNC
Available Options
Automation Options
  • Layout Drawing
  • Operator’s Manual
  • Rotary Table Series Flyer
VIDEOS
CYCLOIDAL ROTARY DRIVE
The cycloidal rotary drive system – designed for machine tools and robotics – provides a great combination of speed, accuracy, and durability. The rugged design provides long service life, with little or no maintenance, and is especially durable in a crash. The cycloidal rotary drive can be back driven to absorb energy from an impact. The shock-load capacity is 5 times the rated torque of the gearbox, and the entire gearbox is a simple drop-in replacement, should damage occur.
CYLINDRICAL ENGRAVING USING G47/G107
Easily hand-program 4th-axis engraving on your Haas mill – without a CAM system. With G47 and G107, engraving on a cylindrical part couldn’t be easier.
UNWIND YOUR HAAS ROTARY QUICKLY
Today, Mark solves an issue every Haas Rotary user faces at some point: How do I get my rotary back to zero quickly?
How to Program a SAFE TOOL CHANGE POSITION
Mark shows how to command a safe tool change position to avoid crashing a tool into your fixture or rotary. It’s all done with a simple program, and referenced with an M-code.
Meet your new 5-axis compact machine
If you make small parts and have multiple setups, this rotary is the perfect solution. Lightning fast and accurate, the TRT100 fits in nearly every Haas mill, and will help you cut cycle times and boost your shops efficiency.
RELATED PRODUCTS
Vertical Configuration
Product Image
HRT310SS
  • 1 Spindles
    CNY ONLY
Learn More Build & Price
Smaller Platter
Product Image
HRT210SS
210 mm High-Speed Rotary Table
  • 1 Spindles
  • 210 mm Platter Size
  • 110 ft-lb Max Torque
  • 490 °/sec Max Speed
    CNY ONLY
Dual-Axis
Haas TRT310
TRT310
310 mm Tilting Rotary Table
  • 1 Spindles
  • 300 ft-lb Max Torque
  • 75 °/sec Max Speed
    CNY ONLY
Build & Price
Get Started
Need More Information?
