DC-3/40 Drill Center
  1. Vertical Mills
  2. High-Speed Drill Centers
  3. DC-3/40 Drill Center
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
High-Speed Drill Center with 78.7" x 19.7" x 11.8" travels, 40 taper
The DC-3/40 is a gantry-style drill/tap machine with 78.7" (2000 mm) of X-axis travel to accommodate long, narrow parts or high-density production setups. The machine’s gantry-style spindle head travels in the X and Z axes, while the table travels in Y, and is fully supported along its length to handle heavier loads.
The machine is equipped with a 10,000-rpm 40-taper spindle and high-speed turret-style tool changer to minimize cut-to-cut times and shorten cycle times. Choose the optional 12,000-rpm or 15000-rpm spindle to cut production times even further.
Well suited to the construction, automotive, and aviation industries, the DC-3/40 can process parts more than 6.5 ft (2 m) long and 1.6 ft (0.5 m) wide, in a variety of shapes and profiles, such as long extrusions, steel channel, angle iron, and pipe.
  • 78.7" (2000 mm) X travel to handle long parts and high-density setups
  • 10,000-rpm 40-taper spindle (12,000-rpm or 15,000-rpm available)
  • High-speed turret-style tool changer, 20 tools
  • Rear chip discharge with front chip flush
See Available Stock
Current Lead Time
  • 40 Taper
  • 3 Axis
  • 10k RPM
  • 20 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
Available for order, with estimated delivery Q2 2026.
HAAS HIGH-SPEED DRILL CENTERS
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Machine Info
    • Rotary Fit chart
    Travels S.A.E METRIC
    X Axis 78.70 in 2000 mm
    Y Axis 19.70 in 500 mm
    Z Axis 11.80 in 300 mm
    Spindle Nose to Table (~ max) 17.7 in 450 mm
    Spindle Nose to Table (~ min) 5.9 in 150 mm
    Spindle S.A.E METRIC
    Max Rating 15.0 hp 11.2 kW
    Max Speed 10000 rpm 10000 rpm
    Max Torque 52.0 ft-lbf @ 3000 rpm 70.5 Nm @ 3000 rpm
    Taper CT40 CT40
    Bearing Lubrication Grease Packed Grease Packed
    Cooling Liquid Cooled Liquid Cooled
    Table S.A.E METRIC
    Length 82.7 in 2100 mm
    Width 19.7 in 500 mm
    T-Slot Width 0.630 in 16 mm
    T-Slot Center Distance 3.94 in 100 mm
    Number of Std T-Slots 5 5
    Max Weight on Table (evenly distributed) 1323 lb 600 kg
    Feedrates S.A.E METRIC
    Max Cutting 1100 ipm 27.9 m/min
    Rapids on X 1200 ipm 30.5 m/min
    Rapids on Y 1400 ipm 35.6 m/min
    Rapids on Z 1400 ipm 35.6 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 2054 lbf 9137 N
    Max Thrust Y 2054 lbf 9137 N
    Max Thrust Z 2054 lbf 9137 N
    Tool Changer S.A.E METRIC
    Type Turret Turret
    Capacity 20 20
    Max Tool Diameter (full)** 4.3 in 110 mm
    Max Tool Diameter, Large (adjacent empty)** 6.3 in 160 mm
    Max Tool Length (from gage line) 7.90 in 200 mm
    Max Tool Weight 11.0 lb 5.0 kg
    Tool-to-Tool (avg) 1.50 s 1.50 s
    Chip-to-Chip (avg) 2.50 s 2.50 s
    Tapping S.A.E METRIC
    Max Tapping Speed 5000 rpm 5000 rpm
    General S.A.E METRIC
    Coolant Capacity 66 gal 250 L
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 10000 rpm 10000 rpm
    Spindle Power 15.0 hp 11.2 kW
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    AVAILABLE OPTIONS
    RELATED PRODUCTS
    Standard Features
    • 10,000-rpm 40-Taper Spindle, DC Series
    • 20-Tool Turret-Style Tool Changer
    • Window Air Blast
    • 66-Gallon (250 liter) Coolant Tank
    • Through-Spindle Coolant Ready
    • Multi-Stage Coolant Pump
    • Control Widescreen Monitor
    • Ethernet Interface
    • Power Surge Protection
    • Advanced Tool Management
    • Media Display M-Code; M130
    • Safe Run
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    • Convenience Package
    • Phone Charging Stand
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    • Installation Guide (Coming Soon)
    • Layout Drawing
    • Torque Chart
    • Operator’s Manual
    RELATED PRODUCTS
    SMALLER VERSION
    Haas DC-1
    DC-1 Drill Center
    High-Speed Drill Center with 23.6" x 17.7" x 13" travels, 30 taper
    • 30 Taper
    • 3 Axis
    • 10k RPM
    • 21 Tool Capacity
        CNY ONLY
    Learn More Build & Price
    DIFFERENT APPROACH
    Haas DT-2
    DT-2
    CNC Drill/Tap Center with 28" x 16" x 15.5" travels
    • 30 Taper
    • 3 Axis
    • 10k RPM
    • 20+1 Tool Capacity
        CNY ONLY
    COMPACT 40-TAPER
    Haas Super Mini Mill
    Super Mini Mill
    Super-Speed Mini Vertical Mill with 16" x 14" x 15" travels
    • 40 Taper
    • 3 Axis
    • 10k RPM
    • 30+1 Tool Capacity
        CNY ONLY
    HA5C2 DC-3/40 POSITIVE FIT
    HA5C2-T DC-3/40 POSITIVE FIT
    HA5C3 DC-3/40 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HA5C3-T DC-3/40 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HA5C DC-3/40 POSITIVE FIT
    HA5C-T DC-3/40 POSITIVE FIT
    HA5C4 DC-3/40 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HA5C4-T DC-3/40 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HA5CS DC-3/40 POSITIVE FIT
    T5C DC-3/40 POSITIVE FIT
    HRT100 DC-3/40 POSITIVE FIT
    HRT160 DC-3/40 POSITIVE FIT
    HRT160SP DC-3/40 POSITIVE FIT
    HRT160SS DC-3/40 POSITIVE FIT
    HRT210 DC-3/40 POSITIVE FIT
    HRT210HS DC-3/40 POSITIVE FIT
    HRT210HT DC-3/40 POSITIVE FIT
    HRT210SP DC-3/40 POSITIVE FIT
    HRT210SS DC-3/40 POSITIVE FIT
    HRTA5 DC-3/40 POSITIVE FIT
    HRTA6 DC-3/40 POSITIVE FIT
    TH240 DC-3/40 POSITIVE FIT
    TRT70 DC-3/40 POSITIVE FIT
    HA2TS DC-3/40 POSITIVE FIT
    T5C2 DC-3/40 POSITIVE FIT
    T5C3 DC-3/40 POSITIVE FIT
    T5C4 DC-3/40 POSITIVE FIT
    HQDA5 DC-3/40 POSITIVE FIT
    HQDA6 DC-3/40 POSITIVE FIT
    HRT210S DC-3/40 POSITIVE FIT
    Build & Price
    Get Started
    Need More Information?
