Cobot Stand, Adjustable (CBT STAND-ADJ 24-36)
Product Image
GET QUOTE
Adjustable Cobot Stand, 24"-36"
    CNY ONLY
Easily adjust the height of your cobot
  • Option Info
  • Specs
OVERVIEW
DOCUMENTS
AVAILABLE ON THESE MACHINES
Easily and quickly adjust the height of the cobot for better reach, depending on your application. This sturdy telescoping stand adjusts from 24" to 36" (610-914 mm) height, in 2" (51 mm) increments.
  • Easily adjusts from 24" to 36" (610-914 mm)
  • Top mounting plate accepts all Haas cobots
  • Base plate has leveling screws for easy adjustment
  • Heavy-duty square tube/sheet metal construction
Top Plate and Base Plate Dimensions
Download 3D Model
SERVICE DOCUMENTS
Type Pedestal
Robot Series HC5 (5kg x 800mm), HC10 (10kg x 1000mm), HC15 (15kg x 1300mm)
Material Steel
[a] Dimension 10.551 in \ 268.0 mm
[b] Dimension 8.976 in \ 228.0 mm
[c] Dimension 9.449 in \ 240.0 mm
[d] Dimension 8.465 in \ 215.0 mm
[OAL] Overall Length 11.8 in \ 300.0 mm
[OAW] Overall Width 11.8 in \ 300.0 mm
[OAH] Overall Height 24.0-36.0 in \ 609.6-914.4 cm
Incremental Step 2.0 in \ 50.8 mm
Weight 78.0 lb \ 35.4 kg
Need More Information?
