7 - Mill - TouchScreen Feature
Mill Operator's Manual
  • 0 - Mill - Table of Contents
  • 1 - Mill - Introduction
  • 2 - Mill - Legal Information
  • 3 - Mill - Safety
  • 4 - Mill - Control Pendant
  • 5 - Mill - Control Display
  • 6 - Mill - Device Manager
  • 7 - Mill - TouchScreen Feature
  • 8 - Mill - Part Setup
  • 9 - Mill - Umbrella Tool Changer
  • 10 - Mill - SMTC
  • 11 - Mill - Operation
  • 12 - Mill - Programming
  • 13 - Mill - Macros
  • 14 - Mill - Control Icons
  • 15 - Mill - Remote Jog Handle
  • 16 - Mill - Options Programming
  • 17 - Mill - G-Codes
  • 18 - Mill - M-Codes
  • 19 - Mill - Settings
  • 20 - Mill - Other Equipment
  • 21 - Eco Mode
  • 7.1 Overview
  • 7.2 Navigation Tiles
  • 7.3 Selectable Boxes
  • 7.4 Virtual Keyboard
  • 7.5 Program Editing
  • 7.6 Maintenance
7.1 TouchScreen Overview
LCD Touchscreen Overview
The touchscreen feature allows you to navigate the control in a more intuitive way.
NOTE: If the touchscreen hardware is not detected at power on, a notification 20016 Touchscreen not detected will appear in the alarm history.
Settings
381 - Enable / Disable Touchscreen
383- Table Row Size
396 - Virtual Keyboard Enabled
397 - Press and Hold Delay
398 - Header Height
399 - Tab Height
403 - Choice Popup Button Size
Touchscreen Status Icons
[1] Software does not support Touchscreen
[2] Touchscreen is Disabled
[3] Touchscreen is Enabled
An icon appears on top left of the screen when the touchscreen is enabled or disabled.
Functions excluded from Touchscreen
Functions Touchscreen
RESET Not available
Emergency Stop Not available
Cycle Start Not available
Feed Hold Not available
7.2 TouchScreen Overview
LCD Touchscreen - Navigation Tiles
Press the Menu[1] icon on the screen to display the display icons [2].
Settings options Icons [1].
Press and hold the display icon, to navigate to a specific tab. For example if you want to go to the Network page, press and hold the settings icon until the settings options [3] are shown.
Press the back icon to go back to the main menu.
To close the popup box touch anywhere else outside the popup box.
Operation Mode Panel
Press the upper left corner [1] of the screen to have the operation mode panel popup box [2] to appear.
Press the mode icon to put the machine in that mode.
LCD Touchscreen - Selectable Boxes
Icon Help
  • Touch and hold the icons [1] on the bottom of the screen to see the meaning [2] of the icon.
  • The help popup will disappear when you let go of the icon.
Selectable tables and function buttons.
  • The rows and columns fields [1] on tables are selectable. To increase the row size refer to setting 383 - Table Row Size.
  • The function button icons [2] that appear on the boxes can also be pressed to use the function.
Selectable Display Boxes
  • Display boxes [1 - 7] are selectable.
    For example if you want to go to the Maintenance tab, press the coolant display box [4].
LCD Touchscreen - Virtual Keyboard
The virtual keyboard allows you to input text on the screen, without using the keypad.
To enable this function set setting 396 - Virtual Keyboard Enabled to On.
Press and hold any input line for the virtual keyboard to appear.
The keyboard can be moved holding your finger down on the blue top bar and dragging it to a new position.
The keyboard can also be locked in place by pressing the lock icon [1].
7.5 Program Editing
Drag and Drop from List Program
You can drag and drop programs from List Program to MEM by dragging the file [1] over to the MEM display.
Copy, Cut, and Paste Handle Bars
In edit mode you can drag your fingers across the code to use the handle bars to copy, cut and paste a section of the program.
7.6 TouchScreen Maintenance
LCD Touchscreen - Maintenance
Touchscreen Configuration Tab
Use the touchscreen configuration page to calibrate, test, and restore default settings. The touchscreen configuration is located in the maintenance section.
Press Diagnostic to go to the Maintenance and navigate to the Touchscreen tab.
