24V - Work Light - Replacement Guide - AD0548
Service Home How To Procedures 24V - Work Light - Replacement Guide - AD0548
Recently Updated Last updated: 11/17/2025
24V LED - Work Light - Replacement Guide
AD0548
- Jump to Section - 1. Introduction 2. Replacement Guide Back to Top
This document outlines where to find instructions for upgrading work lights to the 24VDC work light. Use this guide to determine if a new kit is needed and its respective part number.
Replacement Guide
120VAC Kit P/N Description Is a New Kit Needed? 24VDC Equivalent Kit P/N / Decription Upgrade Instructions
93-2378 SERVICE KIT LAMP LED 20 WATT WITH C13 No N/A Refer to Work Light - 20W Thin LED - Magnetic-Mounted - Replacement.
93-2815 BRACKET, LED 50W N/A N/A N/A
93-2908 HIL LIGHT UPGRADE KIT SINGLE No N/A Refer to High Intensity Lighting LED Upgrade procedure.
93-2888 WRITING TABLE WORK LAMP KIT Yes 93-1000514 VF-6 TO VF-9 24V WRITING TABLE KIT Refer to 24V Table Work Light - Installation - NGC procedure.
93-1000521 VF-10 TO VF-11 24V WRITING TABLE  KIT
93-1000522 VF-12 24V WRITING TABLE KIT
93-1000511 UMC-500-1000 W/PP 24V WRITING TABLE KIT
93-1000292  WORK TABLE LIGHT 93-1000512 UMC-500-1000 W/O PP 24V WRITING TABLE KT
93-1000520 UMC-1500 DUO 24V WRITING TABLE KIT
93-1000513 EC-1600/UMC-1600 24V WRITING TABLE KIT
93-1000296 WRITING TABLE 24V 30W LED FIELD INSTALL
N/A
93-1000009 WL KIT FOR MM/TM WITH 3" PENDANT No Refer to Work Light Kit - Installation - Mini Mill - Toolroom Mill procedure.
93-1000010 WL KIT FOR MM/TM WITH 6.5" PENDANT No N/A Refer to Work Light Kit - Installation - Mini Mill - Toolroom Mill procedure.
93-1000288 HIGH INTENSITY LIGHTING Yes 93-1000278 HIL-24V FIELD INSTALL Refer to 24V High Intensity Lighting - Installation procedure.
93-32-0404 SERVICE KIT LAMP LED 20 WATT 7X7 Yes 93-3055 SERVICE KIT LAMP 24V 30W LED Replace the lamp and reuse the existing bracket.
93-32-0405 SERVICE KIT LAMP LED 30 WATT 9X9
93-32-0416 SERVICE KIT LAMP LED 50 WATT 11X11 Yes 93-3324 SERVICE KIT LAMP 24V 50W LED
Use as a one to one service replacement for the 50W lamp itself and reuse the existing bracket.
