115V LED - Work Light - Magnetic-Mounted - Replacement - AD0269
Service Home How To Procedures 115V LED - Work Light - Magnetic-Mounted - Replacement - AD0269
Recently Updated Last updated: 11/17/2025
AD0269
Applies to machines built from: January, 2000
- Jump to Section - 1. Document Applies to these Parts 2. Tools Required 3. 115V LED - Work Light - Magnetic-Mounted - Replacement (2 steps) Back to Top
KIT PN: 93-2378, SERVICE KIT LAMP LED 20W. QTY: 1
[A] 32-0404 QTY: 1 WORKLIGHT, LED LAMP ASSEMBLY SLIM 20W 7X7
[B] 76-2212 QTY: 4 CRIMP TYPE WIRE NUT 22-12NYLON INSUL CLO
[C] 79-5803 QTY: 1 C13 WORK LAMP POWER CBL 1 FT
Tools Required
  • Crimp Plier/Wire Stripper
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Disconnect the work light cable [1] from the power extension cable [3] that comes out of the control cabinet.
 Note: The power extension cable is in the cable channel on top of the machine. The path of the cable is not the same on all machines.
Remove the installed work light.
If the power extension cable has a Molex connector, do this:
  • Remove the Molex connector [2] from the power extension cable [3].
  • Connect the power extension cable [3] to the new female C13 WORK LAMP POWER CABLE [C]. Use the CRIMP WIRE NUTS [B].
Attach the LED LAMP ASSEMBLY [A] to the machine at a position that fully illuminates the workpiece.
Put the male C14 cable [2] from the 20W LED work light through the hole in the top of the enclosure [1].
 Note: On some machines, the hole in the enclosure and grommet [1] is too small for the male C14 connector. Make the holes larger.
Install the male C14 cable [2] in the same cable channel as the removed work light cable.
Connect the male end of the work light C14 cable [2] to the female C13 WORK LAMP POWER CABLE [C] .
