320V Power Supply (MMPS) - Fuse Replacement - AD0446
Service Home How To Procedures 320V Power Supply (MMPS) - Fuse Replacement
Recently Updated Last updated: 11/02/2020
AD0446
- Jump to Section - 1. Introduction 2. Electrical Safety 3. Fuse Check / Replacement 4. Verify Machine Operation Back to Top
This procedure will show you how to check and replace the fuse 320V Power Supply (MMPS).
Compatibility
Machines equipped with 320V Power Supply (32-5566A).
This Procedure Applies to the Following Parts:
  • 93-3039 320V Power Supply (MMPS) 40A Fuse
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Turn off the main circuit breaker.
Danger:  Do not discharge the power supply using a resistor, this will cause the fuse to blow.  Wait until the HV light [1] on the 320V Power Supply turns off.
The fuse [2] is inside the 320V Power Supply.
Remove the old fuse from the fuse holder [3].
Set the multimeter [4] to Ohms.
Probe the metal ends of the fuse.
Replace the fuse if the multimeter reads open (O.L).
Power on the machine.
Zero Return and verify that there are no alarms generated during this process.
If alarms occur, check the fuse again and check for a short circuit in the axis drive system.  Refer to the following troubleshooting guides:
Sigma 5 - Axis Servo Motor and Cables - Troubleshooting Guide
Servo Amplifier - Troubleshooting Guide
High Voltage 320V Power Supply (MMPS) - Troubleshooting Guide
