P-COOL - Operation
Service Home How To Procedures P-COOL - Operation
P-COOL - Operation
5.2 P-COOL - Operation
Recently Updated Last updated: 02/28/2022
P-COOL - Operation
Applies to machines built from: January, 1992
This procedure tells you how to find the best Programmable Coolant (PCOOL) spigot position for each tool. The PCOOL spigot adjusts its position when the program calls a tool offset.
 Caution: Do not move the PCOOL spigot by hand. This causes damage to the motor. Use only control commands.
Software Required:
  • Mill Software Version 4.19 or higher
  • Next Generation Control
Positioning
Set the ball valve to the PCOOL position.
 Note: This step is necessary only when you have a ball valve control to change between conventional coolant (lock lines or coolant ring) or PCOOL.
Valve placement and style can be different from the illustration.
Press [OFFSET] until the TOOL OFFSET tableappears on the display.
Command the first tool into the spindle.
Classic Haas Control
Press [OFFSET] until the TOOL OFFSET table [1] appears on the display.
Press [COOLANT] to start the coolant flow.
Press [CLNT UP] or [CLNT DOWN] to change the position of the spigot.
 Note: Continue to the next step after you find a good position, where the coolant sprays on the tool tip.
Press [COOLANT] to stop the coolant flow.
Record the value next to Coolant Position [1] at the bottom of the TOOL OFFSET table.
Record the value next to CLNT POS [1] at the bottom of the TOOL OFFSET table.
Highlight the tool offset you want to adjust.
Select the COOLANT POSITION column.
Type the coolant position number that you recorded in step 4.
Press [F1] to enter the value into the COOLANT POSITION column.
 Note: The PCOOL spigot adjusts to the position in the COOLANT POSITION column when the program calls a tool offset.
Select the COOLANT POSITION column [1].
Other Positioning Methods
You can also use these methods of changing the position of the coolant spigot.
  1. Coolant Position System Variables
    • You can specify the coolant positions for tools 1 through 200. The systems variables you will use are 3401 through 3600.
    • Example: #3401=15 sets the coolant position for Tool 1 to position 15.
    • The machine must have Macros enabled.
  2. Coolant Position in the Program Blocks
    • You can adjust the spigot in a program block with an M34 or M35 command.
    • The M35 command moves the spigot one position up.
    • The M34 command moves the spigot one position down.
