Axis Grid Offset - Mill 13.14 or Higher and Lathe 6.11 or Higher
Service Home How To Procedures Axis Grid Offset - Mill 13.14 or Higher and Lathe 6.11 or Higher
Recently Updated Last updated: 11/26/2018
- Jump to Section - 1. Axis Grid Offset - Mill 13.14 or Higher and Lathe 6.11 or Higher (2 steps) Back to Top
This procedure tells you how to set the axis grid offset on machines with Mill software version 13.14 or higher and Lathe software 6.11 or higher. This automatically changes Parameter 125.
Press [POWER ON].
Release [EMERGENCY STOP].
Press [RESET].
Change SETTING 7 PARAMETER LOCK to OFF.
Change the GRID OFFSET parameter to 0. For example, the X-Axis parameter is Parameter 125.
Enter DEBUG mode.
Zero return the axis. For example, zero return the X Axis.
Type GRID and the first letter of the axis. For example, GRID X for the X Axis.
Press [WRITE/ENTER].
The screen shows GRID OFFSET DONE [1].
If necessary, do this procedure again for each other axis.
Cycle Power on the machine.
Zero return all axes to make sure there are no alarms.
If you do this procedure for the Z-Axis on a VMC, the home position changes. You must do the Umbrella Tool Changer - Set Parameter 64 - Z-Axis Tool Change Offset or the VMC - Side-Mount Tool Changer - Set Parameter 64 - Z-Axis Tool Change Offset procedure.
For VMC's, you must also do the Wireless Intuitive Probe System (WIPS) Calibration procedure.
If you do this procedure for the A- or C-Axis on a UMC-750, the home position changes. You must calibrate the probe. Refer to the UMC Level and Alignment video (11:30).
