CL-1 Autodoor Installation
Service Home How To Procedures CL-1 Autodoor Installation
3.4 CL-1 Autodoor
Recently Updated Last updated: 04/09/2025
CL-1 - Autodoor Installation
AD0863
This procedure will illustrate how to field install an autodoor system on CL-1 machines.
This Document Applies to the following Service Kits:
  • 93-1001058 AUTO DOOR FIELD INSTALL KIT CL-1
Machine Compatibility :
  • CL-1 Built After 03/2017
Install the air cylinder [1] into the the mounting bracket [2] and hand tighten the locking nut [3].
Slide the mounting bracket through the door wall and use the provided nuts [4] to tighten it onto the door studs then finally install the locking nut to hold it in position [5].
Note : Leave the locking nuts loose to allow for adjustments.
Install the push lock air line fittings [2] into the air cylinder and attach the cylinder to the window bracket [1].
Install the provided hose clamp [1] to the door [2] and run the air line and the sensor cable through it.
Cover the wires with the provided spiral wire wrap and attach them to the door strut [1] and run them through the side bracket [2] and finally through the enclosure hole [3] to the back of the machine.
Run the cable and air lines as illustrated to the lube panel grommet [1].
Push [POWER OFF].
Set main circuit breaker to the OFF position.
Close the primary air valve. This stops the air supply to the machine.
Open the bleed valve on the air manifold until air pressure is released. Make sure the air pressure is 0 psi (0 bar).
Connect the air solenoids [1] into the top of the manifold [2] and connect the air lines [4] into the fittings [3].
Connect the solenoid cables to the door open and door close connectors in the lube panel.
Install the door fully open sensor [1] and connect the other end of the cable to the SIO PCB P27 Front door fully opened input.
Note : Ensure that the machine is off.
Open the window [1] to the end of its travel and verify that the sensor [2] state changes when it is at the position. If not adjust the position until the switch marks when the window is fully opened.
Install the autodoor button [1] in the pendant and connect it to J15 [2] on the SKBIF PCB
Autodoor Activation
Turn on the machine.
Login to the HBC PORTAL.
Download the Auto door option configuration patch files.
Note: The option files will appear on the configuration download page after it has been ordered. If the option does not appear, contact the service department.
Load the option configuration patch file to the control. Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
Verification
Press autodoor button on the side of the control pendant and test the autodoor works correctly.
