Coolant Collector Replacement - ST-20 - AD0432
Service Home How To Procedures Coolant Collector Replacement - ST-20 - AD0432
- Jump to Section - 1. Overview 2. Install New Coolant Collector Adapter (3 steps) Back to Top
Recently Updated Last updated: 04/17/2025
AD0432
Overview
This procedure will show you how to replace the coolant collector on ST machines.
This Document Applies to the following Service Kits:
  • 93-2921 CLNT COLL ADAPTOR KIT ST-20
The kit includes:
  1. O-ring 2-411 Buna x 1 each
  2. Coolant Collector Adapter Ring x 1 each
  3. Socket Head Cap Screws.  Depending on which brand of hydraulic actuator you have, there will be a different bolt pattern that requires either set of screws below.
    • M6 x 16 millimeter x 4 each (shown)
    • M5 x 16 millimeter x 6 each (not shown)
  4. Hole plugs diameter 0.250 inches x 6 each
  5. Reverse compatibility spacer
  6. Electrical Grease (not shown)
Machine Compatibility :
  • ST-20 machines June 2017 and after that have the coolant collector 20-7364 or 20-7364A
  • Open the coolant collector sheet metal enclosure door
  • Lock the spindle to prevent it from rotating
  • Remove the screws that secure the coolant collector to the hydraulic actuator
  • Remove the O-ring and the coolant collector adapter
  • Based on the hole pattern of the hydraulic actuator, line up the new coolant collector adapter with the drain hole [3] at the bottom
    • 6 holes - LMC [2]
    • 4 holes - Samchully [1]
  • Plug the holes of the un-used  hole pattern with the plugs provided in the kit
  • Grease the new o-ring and wrap around the outer diameter of the coolant collector adapter
  • Note: The O-ring will sit on the adapter and should be on the side of the sheet metal that is inside the sheet metal coolant collector box creating a seal to not let coolant past
  • Note: If you are installing this to a machine that previously did not have the coolant collector style with the o-ring, then you will need to install the included spacer  between the hydraulic actuator and the coolant collector to achieve the correct spacing. Two spacers are included depending on which brand of union you have.
  • Install the screws and torque based on the Haas Torque Chart
Lubricate the inner surface of the O-ring [1] with dielectric grease then slide it onto the coolant collector. Install the coolant collector cover [3] onto the O-ring [2]. Install the screws and torque based on the Haas Torque Chart
