E-Vise Ready - Installation - AD0523
Service Home How To Procedures E-Vise Ready - Installation - AD0523
4.2 E-Vise Ready - Installation
Recently Updated Last updated: 04/18/2022
AD0523
This product has been discontinued, documentation is for reference only.
This procedure will show you how to install E-Vise Ready on a VMC machine.
Machine Requirements
  • Note: If the I/O hinge door is already installed, check that it has the CAN system hole pattern.
  • Software version 100.21.000.1100 or higher
  • I/O PCB 34-349xB or higher
  • I/O Firmware 4.10 or higher
  • E-Vise Firmware 1.30
  • TC Firmware 2.06 or higher
 Important: The E-Vise Ready option is NOT COMPATIBLE with machines with the TAB option built before June 2019.
This Kit Applies to the Following Service Kits
  • 93-1000650: E-VISE READY FIELD INSTALL KIT SMALL
  • 93-1000790: E-VISE READY FIELD INSTALL KIT MED VF
  • 93-1000791: E-VISE READY FIELD INSTALL KIT LARGE VF
To install the Haas E-Vise use the following procedure. E-Vise - Field Install Kit
Install E-Vise CAN PCB
If a I/O hinge door is already installed, check that it has the CAN system hole pattern. If not, you can modify your existing hinge door with the hole pattern dimensioned in the drawing.
  • [1] 7.2"
  • [2] 1.718"
  • [3] 0.51"
  • [4] 5.5"
  • [5] 8.0"
Use the supplied standoffs, cable clamp, and screws to mount the can board to the I/O hinge door.
Route the cables behind the E-vise CAN PCB through the hinged I/O door.
33-5308 [1] E-Vise CAN PCB to I/O PCB
33-0644 [2] E-Vise CAN PSUP to PSUP PCB
33-5400 [3] E-Vise CAN PCB to Smart CAN Auto Door PCB
E-Vise Ready - Electrical Installation
Install the conduit clamp to the access hole sheet metal of the machine.
Route cable 33-0645 from J6 on the E-Vise CAN PCB to the E-Vise connector.
Drill a 5/8" hole in the front skirt below the pendant to install the foot pedal cable.
Route cable 32-1390 from P14 on the I/O PCB to the front skirt of the machine to connect to the foot pedal
Air Blast:
The cable from the air blast solenoid goes to the air blast manifold on the E-Vise, route the cable along the same path as the E-Vise cable.
Connect cable 33-0645 [1] from J6 on the E-Vise CAN PCB to the E-Vise connector.
Connect cable 32-1390 [2] from P14 on the I/O PCB to the foot pedal.
Connect cable 33-5308 [3] from J1 on the E-Vise CAN PCB to J2 on the I/O PCB.
Note: If the machine is equipped with CAN Auto Door. Unplug cable 33-5310 [7] from J2 on the I/O PCB. Connect cable 33-5400 [4] from J3 on the E-Vise CAN PCB to cable 33-5310 [7] plugged into J1 on the Auto Door CAN PCB. If it does not have CAN Auto Door, coil the cable and zip tie it to the I/O Hinge Door.
Note: Cable 33-0647 is wired from the factory. For reference only.
Connect cable 33-0644 [6] from the E-Vise PSUP to P5 on the PSUP PCB.
Note: If there is a cable plugged into P5, unplug it and plug it into the pigtail connection on cable 33-0644.
Solenoid 30-13226 - Air Blast:
Remove a NPT plug from the air manifold inside the lubrication cabinet and install the solenoid to the air manifold into the PROGRAMMABLE AIR BLAST SOLENOID [8] location shown.
Connect the black hose to the solenoid.
Plug the solenoid into the PALLET AIR BLAST/PROGRAMMABLE AIR molex connector [9].
 Note: The air lube cable part number will determine where this solenoid connects to:
  • If 33-9085A, plug the solenoid into the TAB UNION SOL connector.
  • If 33-9085C, plug the solenoid into the PALLET AIR BLAST connector.
  • If 33-9085D or 33-9085F, plug the solenoid into the PALLET AIR BLAST/PROGRAMMABLE AIR connector.
The CAN node selector should be set to B [1].
If the machine is equipped with CAN Auto Door, the termination should be set to NO TERM [2]. If the machine does not have CAN Auto Door, the termination should be set to TERM [3].
