E-Vise Field Install Kit - AD0527
Service Home How To Procedures E-Vise Field Install Kit - AD0527
4.1 E-Vise - Field Installation
Recently Updated Last updated: 04/18/2022
E-Vise - Field Install Kit
AD0527
This product has been discontinued, documentation is for reference only.
This procedure will show you how to install the Haas E-Vise on a VMC machine.
Machine Requirements
  • E-Vise Ready Field Install. E-Vise Ready - Installation
  • Note: If the I/O hinge door is already installed, check that it has the CAN system hole pattern.
  • Software version 100.21.000.1100 or higher
  • I/O PCB 34-349xB or higher
  • I/O Firmware 4.10 or higher
  • E-Vise Firmware 1.30
  • TC Firmware 2.06 or higher
This Kit Applies to the Following Service Kits
  • 93-1000614 HEV 4 INCH FIELD INSTALL KIT
  • 93-1000565 HESCV 5 INCH FIELD INSTALL KIT
  • 93-1000613 HEV 6 INCH FIELD INSTALL KIT
Install and square the vise to the table.
See video for a how to guide.
Plug cable 33-0645 from J6 on the E-Vise CAN PCB to the E-Vise connector.
Clamp the conduit to the E-Vise body.
Verify that there is enough slack in the conduit when at the far end of travel of the X-axis and Y-axis. Verify that the conduit isn't caught between the table and sheet metal when at the close end of travel of the X-axis and Y-axis.
Parameters and Firmware Updates
Turn on the machine.
Go into Service Mode and set parameter 9011.001 CAN NODE 11 (EVISE) ENABLE to TRUE.
Go to the Diagnostics > System tab. Verify that you have:
  • E-Vise Firmware 1.29 or higher
Refer to the following procedures:
  • Software Update - (Option 2) - NGC
  • I/O PCB, Regen Vector Drive, Auto Door Firmware - Update - NGC
E-Vise - Setup
Press [CURRENT COMMANDS] and navigate to Devices > Workholding > Vise 1.
Press [ALTER] to setup the vise
Press [E-Stop] and select 4: Haas Electric V2
Press [ALTER] to go back to the vises view
Press [F2] to clamp/unclamp the vise in the Workholding tab
E-Vise - Air Blast
Follow these steps for the E-Vise - Air Blast
Attach the air blast manifold [1] to the E-Vise as shown, use the hardware provided.
Route the air blast hose [1]  to the manifold from the solenoid in the lube panel and attach as shown.
Attach the air blast hoses [2] to the air blast manifold where needed.
Place the e-vise decal [1] on the front of the machine as shown.
E-Vise - Electrical Diagram
Connect cable 33-0645 [1] from J6 on the E-Vise CAN PCB to the E-Vise connector.
Connect cable 32-1390 [2] from P14 on the I/O PCB to the foot pedal.
Connect cable 33-5308 [3] from J1 on the E-Vise CAN PCB to J2 on the I/O PCB.
Note: If the machine is equipped with CAN Auto Door. Unplug cable 33-5310 [7] from J2 on the I/O PCB. Connect cable 33-5400 [4] from J3 on the E-Vise CAN PCB to cable 33-5310 [7] plugged into J1 on the Auto Door CAN PCB. If it does not have CAN Auto Door, coil the cable and zip tie it to the I/O Hinge Door.
Note: Cable 33-0647 is wired from the factory. For reference only.
Connect cable 33-0644 [6] from the E-Vise PSUP to P5 on the PSUP PCB.
Note: If there is a cable plugged into P5, unplug it and plug it into the pigtail connection on cable 33-0644.
Solenoid 30-13226 - Air Blast:
Remove a NPT plug from the air manifold inside the lubrication cabinet and install the solenoid to the air manifold into the PROGRAMMABLE AIR BLAST SOLENOID [8] location shown.
Connect the black hose to the solenoid.
Plug the solenoid into the PALLET AIR BLAST/PROGRAMMABLE AIR molex connector [9].
 Note: The air lube cable part number will determine where this solenoid connects to:
  • If 33-9085A, plug the solenoid into the TAB UNION SOL connector.
  • If 33-9085C, plug the solenoid into the PALLET AIR BLAST connector.
  • If 33-9085D or 33-9085F, plug the solenoid into the PALLET AIR BLAST/PROGRAMMABLE AIR connector.
