Haas Robot Package - Quick Mastering
Service Home How To Procedures Haas Robot Package - Quick Mastering
Recently Updated Last updated: 01/25/2022
Under Construction
This procedure outlines how to quick master the robot if the batteries have completely died.
Requirements:
  • Replace the batteries using the Battery Replacement procedure.
  • A laptop is needed to connect to the virtual teach pendent.
Only perform this procedure if the batteries have completely died or if the batteries were removed AND the robot or machine was turned off.
Quick Mastering
Follow this video to connect to the virtual teach pendent on a laptop.
Go into the Navigate iPendent to check Master/Cal is enabled.
Click MENU>NEXT>SYSTEM>Master/Cal, it will pop-up in the list on the screen as shown.
Skip this step if Master/Cal is already enabled.
If it is not enabled, follow these steps:
  •  Go to the System Variables screen: MENU>NEXT>SYSTEM>Variables
  • Scroll down to $MASTER_ENB
  • Set $MASTER_ENB to 1 by pressing 1 and pressing enter
Reset Pulsecoder Alarm
Go the the Master/Cal screen: MENU>NEXT>SYSTEM>Master/Cal
Click RES_PCA [1], the pendent will display a message asking if you want to reset pulsecoder alarms.
Click Yes [2], a message will appear as shown that says 'Pulsecoder alarm reset!' [3]
After the pulsecoder alarm has been reset, cycle power on the robot. DO NOT cycle power on the machine.
Re-establish pulse for each axis
When axes lose power, the pulse on each axis needs to be re-established. This is done by jogging each joint at least 10-20 degrees in each direction.
Follow these steps to do this:
  • Enter the Jogging iPendent from the Robot Homepage.
  • Click the Jog Panel button [1] to open the Jog Panel, make sure the E-Stop on the machine is released.
  • Click Reset [2] to reset all faults
  • Click the switch [3] to turn it on
  • Click Shift [4] and then jog the joints
Note: If an alarm pops up while jogging, reset the alarm and lower the jogging rate [5] until the arm is able to be jogged again. This will happen once the arm has left the DCS zone and it will need to be jogged at a slower rate.
Copy Master Count to Reference Count & Checking the Zero Reference Position
Go back to the Navigate iPendent.
Copy the Master Count values to the Reference Count values by doing the following:
  • Go to the System Variables screen: MENU>NEXT>SYSTEM>TYPE>Variables
  • Scroll down to $DMR_GRP (should be number 199) and once it is highlighted, hit ENTER twice and the variables shown in [1] should be on the screen.
  • Scroll to $MASTER_COUNT and click DETAIL when it is highlighted. Take note of these values.
  • Press PREV to go back to the variable list and then go into the $REF_COUNT by pressing DETAIL when it is highlighted. Copy the values from the $MASTER_COUNT by typing them in and pressing enter to change the values.
  • Press PREV to go back to the variable list and set $REF_DONE to TRUE
While still inside $DMR_GRP[1] System Variables, go to $REF_POS and make sure the axis values are set to a value of 0 as shown in [2].
Line Up Witness Marks
Go back to the Jogging iPendent, open the Jog Panel and turn on the switch.
Jog each joint so that the witness marks line up, use the image shown to locate the positions of the witness marks on HRP-1.
For HRP-1 witness mark locations, see page 76 of the HRP-1 Mechanical Unit Operator's Manual in the link below.
For HRP-2 witness mark locations, see page 82 of the HRP-2 Mechanical Unit Operator's Manual in the link below.
For HRP-3 witness mark locations, see page 117-118 of the HRP-3 Mechanical Unit Operator's Manual in the link below.
Note: The witness marks on Joint 6 may not be visible, remove the gripper and make sure the dowel pin hole is positioned upward.
HRP-1 Fanuc Robot M-200iD Mechanical Unit Operator's Manual
HRP-2 Fanuc Robot M-20iD/25 Mechanical Unit Operator's Manual
HRP-3 Fanuc Robot M-710iC/50 Mechanical Unit Operator's Manual
Quick Master and Calibrate
After lining up the witness marks, the robot is at its zero position.
Go to Master/Cal screen: MENU>NEXT>SYSTEM>Master/Cal
Note: if Master/Cal is not showing up, go back to step 2 to enable it again.
Scroll to QUICK MASTER and press ENTER to select [1].
A message will appear asking if you want to quick master, click YES [2].
A message will appear saying that the Robot has been mastered.
While still in Mast/Cal mode, scroll to CALIBRATE and press ENTER [3].
Click YES when the screen asks if you want to calibrate [4].
A message will display saying that the robot has been calibrated, then press DONE.
Apply DCS Parameters
After quick mastering and calibrating, the robot will be in a faulted state until you apply DCS parameters.
Go into the Jogging iPendent mode.
Go to the DCS menu: MENU>NEXT>SYSTEM>DCS
Scroll down to option 13 - Mastering parameters.
Click APPLY to apply the changes and press OK.
Enter 1111 for the Master Code.
Cycle power on the robot.
Verify Quick Mastering
Move all joints to zero and check to see if the lines on both sides of the joint are lined up. If they are not lined up, repeat the procedure.
