Horizontal Gearbox - Replacement - NGC AD0466
Service Home How To Procedures Horizontal Gearbox - Replacement - NGC AD0466
Recently Updated Last updated: 01/12/2024
AD0466
- Jump to Section - 1. Introduction (1 step) 2. Horizontal Gearbox - Removal (5 steps) 3. Horizontal Gearbox - Installation (1 step) Back to Top
This procedure explains how to replace the 16DP-C Gearbox on NGC EC-1600's. For 16DP-C Gearbox replacements on Coldfire machines please refer to the EC-1600 - GEARBOX - 16DP-C - REPLACEMENT AD0152
  • 93-2133A GEARBOX EC-1600/YZT 6K 16DP-C
  • 93-2134A GEARBOX EC-1600/YZT 10K 16DP-C
  • 93-30-11789 GEARBOX ASSY 16DP-C 50T EC-1600
  • 93-30-12836 GEARBOX ASSY 50T 16DP-C EC-500
  • 93-30-9983B TRANS EC-1600 6K 16DP-C TBLK
  • 93-30-9984B TRANS EC-1600 10K 16DP-C TBLK
 NOTE: The replacement gearbox does not require an oil pump so it will not come with one.
NOTE: Updated EC-1600 Service Gearboxes built after 11/2022 may not come with surrounding sheet metal, solenoid, and other components. Please use the existing parts when replacing the gearbox
Remove the Y-Axis waycovers and the enclosure panels around the gearbox.
Remove the (4) 1/4-20 spindle fan mounting bolts [1].
Remove the spindle fan [2].
Disconnect all hoses and cables from the TRP [1].
Support the TRP [1] with a lifiting strap connected to a hoist.
Remove the (4) TRP mounting bolts, washers, and springs [2].
Remove the (4) TRP spacers [3].
Hoist the TRP [1] out of the machine.
Disconnect all cables and hoses from the gearbox.
Install a threaded lifting eyebolt [1] into the top of the gearbox.
Remove the (2) 1/4-20 bolts [2] from the motor bracket.
Attach lifting chains [3] from the hoist to the eyebolt and motor bracket.
WARNING: The hoist and chains must have a lifting capacity greater than 300 lbs.
Support the gearbox using the hoist.
Remove the (4) gearbox mounting bolts [1].
Hoist the gearbox out of the machine.
Install the spindle belt [1] onto the spindle.
Hoist the replacement gearbox into the machine.
Install the (4) gearbox mounting screws [2].
Adjust the belt tension using the jack screws located at the bottom of the gearbox mounting plate.  Refer to: Spindle Drive Belt - Tension Adjustment - Gates Sonic Meter - Mill
Torque the gearbox mounting bolts [2].  Refer to: Haas Fastener Torque Specifications
Remove the lifting eye bolt.
Clean the gearbox oil reservoir [3] to remove debris.
Connect all gearbox cables and hoses to the replacement gearbox.
Reinstall the TRP, spindle fan, waycovers, and enclosure panels.
