Coolant Filter - Cast-Aluminum - Upgrade - AD0246
Service Home How To Procedures Coolant Filter - Cast-Aluminum - Upgrade - AD0246
AD0246
Machines built after December 2015 have the cast coolant-filter [1]. This procedure tells you how to replace the standard coolant-filter [2] with the cast coolant-filter [1]. The standard coolant-filter [2] has a plastic reservoir.
 Note: The cast coolant-filter [1] replaces all standard coolant-filters [2].
Note: The coolant filter has been replaced with the chip seperator. For more information regarding the chip seperator click here.
Machine Compatibility
The cast coolant-filter is compatible with VMCs and HMCs.
93-2356 QTY: 1
FILTER, STANDARD COOLANT HEAD/BOWL REPLACEMENT KIT
Standard Coolant Filter Assembly - Replacement
For DM, DT, EC-1600, MM, SMM, and TM machines: Use the (2) crescent wrenches and remove the 1/2" fitting [2]. Use the allen wrench to install the plug [3].
For DM, DT, MM, SMM, and TM machines: Use the (2) crescent wrenches to remove the 5/8" fitting [1] and install the 1/2" fitting [2].
For all machines, go to step 2.
Remove all coolant hoses. Use the (2) crescent wrenches to remove all fittings [3] and the valve assembly [1]. Keep all the fittings. Remove and discard the standard coolant-filter [2].
Attach the cast coolant-filter [5]. Use the Phillips screwdriver and install the (2) screws [6]. Install all coolant fittings [3] and the valve assembly [1].
Connect the hose [4].
When you install the (3) remaining hoses, do these steps for each hose:
  • Install the hose cap [7].
  • Install the hose clamp [8].
  • Use the crimp pliers [9] to crimp the hose clamp [8].
If the machine has 3/4" coolant hoses, use the 1/2"-to-3/4" inch adapter in the kit.
