Standard Coolant - Oil Coolant Separator - Maintenance
Service Home How To Procedures Standard Coolant - Oil Coolant Separator - Maintenance
Recently Updated Last updated: 09/20/2018
Oil/Coolant Separator - Maintenance - Standard Coolant
- Jump to Section - 1. Exploded View 2. Oil/Coolant Separator - Maintenance - Standard Coolant Back to Top
Exploded View
  1. Rear view
  2. Front view
  3. (2) Socket head capscrews (SHCS)
  4. Coolant return hose
  5. Coolant drain hose
  6. (13) Phillips pan head screws
  7. Oil separator tray
  8. Oil separator
  9. Gasket
  10. Input pipe
  11. Coolant drain pipe
  12. Fittings
  13. Mounting bracket
  14. Bubble indicator
 Note: The gasket [9] remains attached to the oil separator tray [7].
Debris in the oil/coolant separator can cause it to clog. This makes coolant overflow from the rear of the casting. This procedure tells you how to clean the parts inside the oil/coolant separator. Always wear proper eye protection when performing maintenance.
Push [EMERGENCY STOP] when you do maintenance on the machine.
Disconnect the coolant return hose [4] and coolant drain hose [5]. Remove the oil separator [8] from the oil separator tray [7]. Remove the (13) screws [6]. Remove the oil separator [8] from the oil separator tray [7].
Clean and remove all chips from the removed parts. Clean the input pipe [10] and coolant drain pipe [11].
Install the parts in the opposite order they were removed. Before you connect the coolant drain hose [5] or the return hose [4], pour coolant into the fitting for the coolant return hose [4] to prime the oil/coolant separator. Continue to install the parts in the opposite order they were removed.
Use the bubble indicator [14] to make sure the oil/coolant separator is level. If it is not level, loosen the (2) SHCS [3] and adjust the oil/coolant separator position until it is level. Tighten the (2) SHCS [3]. Clean any spilled coolant from the floor.
