Through-Tool Air Blast - Installation - VMC - AD0148
Service Home How To Procedures Through-Tool Air Blast - Installation - VMC - AD0148
15.1 TAB - Installation - CHC
Recently Updated Last updated: 02/20/2023
VMC - Through-Tool Air Blast - Installation - CHC
AD0148
This procedure tells you how to install Through-Tool Air Blast (TAB). Perform this procedure on mills:
Machine Compatibility:
  • made after September, 2014.
  • with software version 18.21B or higher.
  • with an inline spindle.
  • equipped with the TSC option.
  • Set setting 32 COOLANT OVERRIDE to NORMAL
This procedure applies to the following service kit:
  • 93-TAB TOOL AIR BLAST 2016-2018 MC W/ BEARINGLESS
Press [POWER OFF].
Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Remove the head covers from the machine.
Remove the plug [2] from the top-center port of the TSC check-valve [1].
Connect a 1/4" NPT by 1/4" NPT adapter [2] to the 1/4" check-valve [3].
Connect a 1/4" NPT to 3/8" push-to-connect fitting [1] to the adapter.
Install the completed 1/4" check-valve assembly [4] to the TSC check-valve [5].
Install the 3/8" tube [6] to the push-to-connect fitting.
Put the 3/8" tube through the cable carrier [1] and behind the control cabinet.
Put the 3/8" tube [2] into the upper right of the air/lubrication cabinet.
Put the 3/8" tube through the back of the of the manifold assembly.
Connect the 3/8” tube to the push-to-connect fitting [1] on the Asco solenoid, as shown.
Find the gray 1/4" tube [2] connected to the TSC regulator [3].
Cut the tube near the TAB manifold.
Connect the upper end of the tube to the upper push-to-connect fitting [4] on the TAB solenoid.
Connect the lower end of the tube to the lower push-to-connect fitting [5] on the TAB solenoid.
Connect the cable from the Asco solenoid into the connector labeled TOOL AIR BLAST [1].
Connect the cable from the remaining solenoid into the connector labeled TOOL AIR BLAST UNION ACTIVATION SOLENOID [2].
Put the cables into the cable manager [3].
Set the main circuit breaker to the ON position.
Press [POWER ON].
For CHC: Set Parameter 1376, TAB VERSION, to 1.
Make sure the TAB system operates correctly. Operate this code in MDI mode:
M73;
G04 P5.;
M74;
G04 P3.;
M99;
M73 starts the TAB. M74 stops the TAB.
Manually operate the TAB:
Press [AUX CLNT]. Press the [RIGHT] cursor arrow.
The tool air blast starts.
Press [AUX CLNT].
The tool air blast stops.
Install the head covers.
