TRT Rotary Air Clamp Provision - Installation - AD0524
Service Home How To Procedures Alarm Search: 4.103 TRT Rotary Air Clamp Provision - Installation - AD0524
7.3 TRT Rotary Air Clamp Provision - Installation
Recently Updated Last updated: 04/12/2022
TRT Rotary - Air Clamp Provision - Installation
AD0524
Revision B - 02/2026
This procedure will explain how to install the Rotary air union on the following units:
  • TRT160 built after 8/16/2019
  • TRT210 built after 03/16/2020
  • TRT310 built after 10/01/2021
NOTE:  The TRT160, TRT210, and TRT310 must have the motor cover with the AUX 1 and AUX 2 port on the rotary axis.
Machine Requirements:
  • Next Generation Control
  • Auto Vise Software Requirements: 100.20.000.1200 or later.
  • Minimum Main IO firmware: version 4.0 or higher.
TRT160
  • AIR-CLAMP-PROV-160 Air Clamp Provision only.
  • AIR CLAMP AUTO 160 Automatic Air Clamp Provision kit.  This kit comes with a foot pedal switch.
  • 93-1000427 AIR CLAMPING PROVISION TRT160 - Manual Air Clamp Provision kit.  This kit comes with a manual switch
TRT 210
  • AIR-CLAMP-PROV-210    Air Clamp Provision kit only.
  • AIR CLAMP PRO-MANU Manual Air Clamp Provision kit.  This kit comes with a manual switch
  • AIR-CLAMP-PRO-AUTO   Automatic Air Clamp Provision kit.  This kit comes with a foot pedal switch.
TRT310
  • AIR CLAMP MANU 310 Manual Air Clamp Provision kit.  This kit comes with a manual switch
  • AIR CLAMP AUTO 310 Automatic Air Clamp Provision kit.  This kit comes with a foot pedal switch.
  • 100MM AIR VISE-MNL 100mm air vise to use with manual switch
  • 100MM AIR VISE-AUT 100mm air vise to use with foot pedal switch.
 Warning: Zero return the unit before installing the air clamp union assembly [1].
Use the SHCS 10-32 [2] to install the assembly onto the unit.
NOTE: The TRT160 will have x4 10-32 screws, while the TRT210 and TRT310 will have 3.
TRT160 and TRT210
The air clamp union should be installed in the correct orientation as shown. Auxiliary port 1 is denoted as [1] and auxiliary port 2 as [2].
TRT310
For TRT160's with equally spaced platter bolts, use the shown orientation with the aux 1 denoted as [1] and aux 2 denoted as [2].
Move the NPT plugs from the auxiliary ports below the unit [1] to the ports shown in position [2].
Install the copper lines and fittings as shown.
[1] Copper tubes (Part number will depend on TRT model)
[2] 58-2110 FITG LUBE COMP NUT BIJUR-M 5/32 (2x)
[3] 58-2100 FITG LUBE COMP SLEEVE 5/32 BRASS
[4] 58-1550 FITG LUBE BIJUR-F NPT1/8M STR BRASS
Remove the plugs [1].
Install 90° compression fittings [2] where the plugs were removed from.
Note: If the TRT is removed from the machine, plug ports with 1/8 NPT plugs to prevent contamination of the air system.
Manual - Air Clamp Provision
Follow this step for the Manual Air Clamp Provision Option.
Install the air switch [1], the switch can be mounted on the inside or outside of the machine via magnet.
Connect the air supply [3] to the air switch [1].
Connect the air lines from the switch [1] to the unit [2].
Note: The AUX 1 port will act as clamp and the AUX 2 port will act as unclamp.
Automatic - Air Clamp Provision - Installation
Follow these steps for the Automatic Air Clamp Provision Option.
Connect the SS braided hoses [1] from the solenoid assembly to the 90° compression fittings [2] at AUX 1 and AUX 2.
Note: The install kits will no longer be shipped with colored zip ties. For reference, the red zip tie denotes clamp, and the green zip tie denotes unclamp.
Solenoid 30-13112 UNCLAMP/CLAMP:
 Warning: E-Stop and turn off the machine before any electrical installation
Remove an NPT plug from the air manifold inside the lubrication cabinet and install the solenoid [1] to the air manifold into the location APC DOOR INTERLOCK/PROGRAMMABLE AIR shown on the AIR - LUBRICATION SYSTEM - PICTORIAL.
Connect the red hose to the top fitting [2] and connect the green hose to the bottom fitting [3].
 Note: The ports that these hoses are installed to will determine if the vise remains clamped when power is cut to the machine. Test at end of installation.
Plug cable 33-0631 in at P50 on the I/O board. Plug the other end of the cable into the APC Door Interlock/Programmable Air location on the solenoid bracket.
Plug the solenoid into 33-0631 at the APC Door Interlock/Programmable Air Molex connector.
Connect cable 33-0732 onto the pressure switch on solenoid 30-13112. Plug cable 33-0738 into P13 on the I/O PCB and connect the other end to cable 33-0732.
Foot Pedal Installation
VF/VM Models
Install the fool pedal cable on the hole located on the front skirt of the machine.
Note: If the foot pedal cable hole is not present, drill a 5/8" hole in the front skirt to install the foot pedal cable.
Route cable 32-1390 from P14 on the I/O PCB to the front skirt of the machine to connect to the foot pedal.
Note: To install the Pneumatic Vise, refer to the TRT Pneumatic Vise - Installation procedure.
