UMC Pneumatic Vise - Installation - AD0543
Service Home How To Procedures UMC Pneumatic Vise - Installation - AD0543
Recently Updated Last updated: 02/11/2022
AD0543
Revision A - 06/2026
This procedure will explain how to install the air vise option on the UMC series machines.
Please refer to the PNEUMATIC WORKHOLDING procedure to install the air booster, workholding manifold, and the other components that drive the air vise.
Pre-requisites:
  • Software version 100.20.000.1110
This document applies to the following part numbers:
  • 05-0408 AIR VISE SELF-CENTER 100mm, UMC
  • 05-0409 AIR VISE SELF-CENTER 150mm, UMC
Blank platters have a no drill zone [1] of  Ø7.25 in. and ↧1.75 in. for custom workholding on these platters.
Machines sold with a blank platter also have the option of purchasing the Haas air vise.
To install the vise the user will need to drill mounting holes outside the no drill zone [1].  Home the B & C-Axis and drill using the hole pattern that follows:
  • 100mm Air Vise – 4x ½-13 at 220mm [2] x 126mm [3] (on center)
  • 150mm Air Vise – 4x ½-13 at 270mm [2] x 252mm [3] (on center)
Use the brake bleed access hole for reference [4].
NOTE: Pictured is a UMC-500 blank platter but the no drill zone and Haas air vise hole pattern will be the same throughout all UMC models.
Ensure the system is not pressurized before installing the vise.
Close the air valve [1] at the bottom of the lube cabinet.
Bleed the remaining air out of the manifold by pulling on the air release [2]. Make sure the gauge on the manifold reads zero.
Remove the (3x) bolts acting as plugs on the coupler [1].
Verify that the vise seal [1] is seated properly. The o-ring side of the seal [2] should be facing toward the UMC rotary.
Note: The seal only sits in one orientation. The location of holes on the coupler are not equally spaced and the seal is made to match the coupler's spacing.
Set the C-axis to its home position.
Clean the mating surface inside the center bore and on the spud of the air  vice.
 NOTE: Always clean inside the center bore for chips before installing the pneumatic vise.
Safely lift the vise and match the holes on the coupler to the holes on the vise.
NOTE: The coupler can only be installed to the platter in one orientation and the holes on the coupler are not equally spaced. This means that the air vise can only be installed in one orientation to function correctly.
Secure the air vise to the platter using the 1/2-13 T-nuts and 1/2-13 SHCS provided.
Re-introduce air to the manifold by turning the valve [1].
