VF-1/2/3/4/5 - X-Axis Way Cover - Replacement - AD0236
Service Home How To Procedures VF-1/2/3/4/5 - X-Axis Way Cover - Replacement - AD0236
Recently Updated Last updated: 10/11/2024
AD0236
- Jump to Section - 1. Introduction 2. Way cover Removal (2 steps) 3. Way Cover Installation (4 steps) Back to Top
This procedure tells you how to replace the X-Axis way cover. The new way cover attaches directly to the guide bars. This gives stronger support for the way cover.
Tools Required:
  • #10-32 Tap and Handle
  • GREASE, CARTRIDGE RED-I 14 OZ
  • SILICONE, RTV 598 BLACK
Service Kits:
This procedure applies to the following service kits. Look at the table below to find the correct kit for your machine.
 Note: Service kit part numbers with an * at the end include the Y-Axis waycover for installation.
Machine Part Number Kit Name
VF-1/1SS 93-4741 WAYCOVER TELES SS X-AXIS VF-1 SVC KIT
VF-2/2SS 93-3404 WAYCOVER SS SVC KIT X-AXIS VF-2
93-1000735* WAYCOVER SS FIELD INSTALL VF-2/2SS
VF-3/3SS 93-3395 WAYCOVER SS SVC KIT X-AXIS VF-3
93-1000737* WAYCOVER SS FIELD INSTALL VF-3/3SS
VF-4/4SS 93-3396 WAYCOVER SS SVC KIT X-AXIS VF-4/5
93-1000740* WAYCOVER SS FIELD INSTALL VF-4/4SS
VF-5/5SS 93-3396 WAYCOVER SS SVC KIT X-AXIS VF-4/5
VF-5XT 93-4744 WAYCVR TELESCOPE SS XAXIS VF-5X SKIT
VM-2 93-3404 WAYCOVER SS SVC KIT X-AXIS VF-2
VM-3 93-3396 WAYCOVER SS SVC KIT X-AXIS VF-4/5
Way cover Removal
Push [POWER OFF.]
Set the main circuit breaker to the OFF position.
Lock the main circuit breaker. Use an approved lock and an approved safety tag.
Remove the X-Axis way cover [1].
Remove the L-bracket [2].
Find the outer (2) holes in the mounting bars for the way cover.
Note: If the holes are not drilled fully through, use a #21 drill bit to drill it through.
Use the #10-32 tap to tap the holes fully through.
Make sure that the transition between the way cover guide bars [1] and the guide [2] in the casting is smooth.
If necessary, use a grinder to adjust the height or the width of the guide bars [3].
Remove chips and debris from the linear guides.
Remove the used gasket or sealant [1] from the table mounting surface.
Clean the table mounting surface.
Apply a thin coat of Red-I grease to the way cover guide bars [2].
Install the way cover over the guide bars.
Attach the way cover end panel to the way cover guide bars with the (2) screws [3].
Move the table to the full X-Axis travel [1].
Fully extend the sections of the way cover [2] to make sure the way cover moves correctly and is the correct length.
Lightly spray a multi-purpose lubricant onto the tops and sides of each of the new way cover panels.
Move the largest section of the way cover away from the table.
Put RTV 598 BLACK SILICONE on the way cover where it touches the table mounting surface [1].
Put a small amount of black silicone on the horizontal seam between the way cover and the table [2].
Attach the way cover to the table with the (8) screws [3].
Remove any silicone that is squeezed out of the space between the way cover and the table.
Push POWER ON.
Check the X-Axis movement to make sure the way cover does not bind.
