HDC-3-5AX Install Guide
PRE-INSTALLATION [GUIDE]
    CNY ONLY
5-Axis CNC double-Column Mill with 150" x 106" x 43" travels
  • HSK-A100 Taper
  • 5 Axis
  • 6000 RPM
  • 50+1 Tool Capacity
  • STEP-BY-STEP GUIDE
  • Layout Drawing
  • Lifting Instructions
  • Rotary Fit
  • Additional Resources
Pre-Installation Checklist
  • Make sure that your floor is correct for the machine. Refer to the “Placement and Preparation” in this document for more information.
STEP-BY-STEP INSTALLATION GUIDE
Foundation
You must put your machine on a solid and stable concrete foundation. This machine requires a 12" (300 mm) concrete foundation, to ensure accurate geometry.
Refer to these specifications:
  • Continuous slab – DO NOT place machines across expansion joints or cracks.
☑ Anchoring
This machine must be anchored for best cutting performance. Click here to view anchoring kits for your machine
  • Download anchoring pattern
☑ Machine Placement
  • Ensure adequate machine installation clearance (see below)
☑ Optional Component Location
  • External Transformers.
Layout Drawing
Download Machine Layout Drawing (PDF)
The HDC-3-5AX is not suitable for overhead lifting. It does not have built-in lifting provisions, and must be lifted by forklift.
Machine Installation Clearance
BRIDGE INSTALLATION OPTION 1: BRIDGE ASSEMBLED TO COLUMNS FROM REAR OF MACHINE.
STEP 1 – ENSURE BOTH DIMENSIONS ‘A’ AND ‘B’ CONDITIONS ARE MET FOR ADEQUATE MACHINE INSTALLATION CLEARANCE.
STEP 2 – INSTALL COLUMNS.
STEP 3 – INSTALL BRIDGE ASSEMBLY (BRIDGE IS STACKED ON COLUMNS BEFORE SADDLE IS IN FINAL POSITION. SADDLE SHOWN IN FINAL POSITION FOR REFERENCE ONLY).
STEP 4 – INSTALL SADDLE ASSEMBLY FROM FRONT OF MACHINE.
BRIDGE INSTALLATION OPTION 2: BRIDGE ASSEMBLED TO COLUMNS FROM FRONT OF MACHINE.
NOTE: BRIDGE ASSEMBLY SHOWN IN SHIPPING CONFIGURATION (WITH FORKLIFT TOOL) FOR INSTALLING ON COLUMNS.
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 6000 rpm 6000 rpm
Drive System Integral Spindle/Motor Integral Spindle/Motor
Spindle Power 60.0 hp 44.7 kW
Full Load Amps (3 Phase) - Low 105 A 105 A
Domestic Pallet for Sheet Metal Crate 96 in x 72 in x 60 in 244 cm x 183 cm x 152 cm
Weight for Sheet Metal Crate 2280 lb 1034 kg
Domestic Pallet, Column Assembly 150 in x 102 in x 87 in 381 cm x 259 cm x 221 cm
Domestic Pallet, Table Assembly 376 in x 91 in x 66 in 955 cm x 231 cm x 168 cm
Weight, Column Assembly, Domestic 7,260 lb 3,293 kg
Weight, Table Assembly, Export 20,860 lb 9,462 kg
Domestic Pallet, Bridge Assembly 240.0 in 120.0 in 133.0 in 610 cm 305 cm 338 cm
Weight, Bridge Assembly, Domestic 23,280 lb 10,560.0 kg
Domestic Pallet for Sheet Metal Crate #2 96.0 in 72.0 in 92.0 in 243.8 cm 182.9 cm 233.7 cm
Weight for Sheet Metal Crate #2, Domestic 2,340 lb 1,061.0 kg
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines CL-1, and CM-1. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
ATTENTION! Optional high-performance spindles have a higher power requirement than the standard spindle. Verify the power requirement before running power for your machine.
Caution:
    • soluble oil coolant
    • semi-synthetic coolant
    • synthetic coolant
General
  • Refer to the Machine Layout Drawing for the location of the machine’s electrical input.
440 V Power *
  • Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines, CL-1 ,and CM-1.
Ground
Three-Phase Power
  • For Mini Mill Series machines, some options, such as Through-Spindle Coolant, require three-phase power.
Single-Phase Power
Wire Size
Service Breaker
Phase Converters
Rotary Fit Chart
* If a rotary product is not listed, it is does not have a compatible fit with this mill.
  • Anchoring Instructions
  • Video Library
  • Operator’s Manual
  • Service
