1 - Haas Air Compressor - Introduction
Haas Air Compressor - Operators/Service Manual
  • 0 - Haas Air Compressor - Table of Contents
  • 1 - Haas Air Compressor - Introduction
  • 2 - Haas Air Compressor - Installation
  • 3 - Haas Air Compressor - Operation
  • 4 - Haas Air Compressor - Maintenance
  • 5 - Haas Air Compressor - Troubleshooting
  • 1.1 Introduction
  • 1.2 Specification
1.1 Introduction
Overview
This manual provides details about how to install, operate and maintain the Haas Air Compressor. It also gives details about the features associated with this product
The Haas Air Compressor will come standard with a maintenance kit for the first round of maintenance. The kit will include:
  • 3 gallons of oil (4 gallons for HAC30-VS machines)
  • Oil filter
  • Air filter
Note: These items are for the first round of maintenance and do not need to be used at installation.
1.2 Specification
Air Compressor Components
The Haas Air Compressor consists of a screw air compressor and a compressed air dryer which are both mounted to a air storage tank.  This section gives the specification for both the fixed speed and variable speed compressors.
Note: Refer to the specification plate on the compressor to confirm incoming power requirements.
Compressor Specifications
HAC15-FS - Specification
Spec Value - SAE Value - Metric
Working Pressure
145 PSI
 10 Bar
Capacity (Free Air Delivery)
53 CFM 1.5 M3/min
Motor Power
15 HP
11 KW
Tank Storage Capacity 52 Gallons 200 L
Noise
64 dB
64 dB
Weight
1014 LBS 430 KG
Dimensions (Length X Width X Height) 66.53in X 27.16in X 64.96in 1690mm X 690mm X 1650mm
Air Outlet Fitting Size RC 3/4"
HAC15-VS - Specification
Working Pressure
145 PSI
10 Bar
Dependent on Motor Speed Dependent on Motor Speed
Motor Power
15 HP
11 KW
Noise
64 dB
64 dB
Weight
1014 LBS 430 KG
Electrical Specifications
HAC15-FS and HAC15-VS - Electrical Specification
Spec Value
Voltage 220V AC - 3 Phase
Power 11 kW
HAC15-EU-FS AND HAC15-EU-VS - Electrical Specification
Spec Value
Voltage 380V AC - 3 Phase
Power 11 kW
HAC30-VS - Electrical Specification
Spec Value
Voltage 220VAC - 3 Phase
Power 22 kW
