4 - Haas Air Compressor - Maintenance
Haas Air Compressor - Operators/Service Manual
  • 0 - Haas Air Compressor - Table of Contents
  • 1 - Haas Air Compressor - Introduction
  • 2 - Haas Air Compressor - Installation
  • 3 - Haas Air Compressor - Operation
  • 4 - Haas Air Compressor - Maintenance
  • 5 - Haas Air Compressor - Troubleshooting
  • 4.1 HAC15 Maintenance
  • 4.2 HAC30 - Maintenance
  • 4.3 HAC15 - SERVICE PARTS LIST
  • 4.4 HAC30 - SERVICE PARTS LIST
HAC15 - Fixed Speed and Variable Speed - Maintenance
Revision B - 09/2025
Overview
This chapter provides information on what maintenance is needed for both the single and variable speed air compressors. There is a maintenance schedule as well as instructions on how to perform the required maintenance.
Maintenance Schedule
This chart details what components need maintenance and the required intervals for performing the maintenance. In addition to following the maintenance schedule below, daily inspection of the air compressor should be performed to keep the components clean and reduce the risk of component failure.
The daily/weekly inspection should consist of:
  • Check oil level
  • Look for oil leakage
  • Check pipelines and air hoses for leaks
  • Check pressure gauge
  • Check auto drainer behavior
  • Manually drain oil-water separators
  • Monitoring the control display
Note: The maintenance schedule below applies to both the single and variable speed air compressors
Important: To ensure compressor performance, follow all items on the maintenance schedule. Also, consult your local municipality's codes for any required annual inspections of the tank itself.
Maintenance Item Interval
Air Filter Clean After 500 Hours Replace After 2000 Hours
Oil Filter* Replace After 3000 Hours
Oil-Air Separator Replace After 3000 Hours
Oil* Replace After 3000 Hours
Oil Level Check Daily
Pre-filter Clean Weekly
Radiator Clean Weekly
Electrical Components and Connector Check After 500 Hours
Oil-Water Separator Filters Check After 500 Hours Replace After 3000 Hours
Drain Oil-Water Separators Weekly
Purge Solenoid Test Weekly
Mesh Purge Line Filter Clean Every 2 Months Or As Needed
Important* For new air compressors, the oil and oil filter need to be replaced after the first 500 hours of run time. After the first replacement, these components can be replaced every 3000 hours of run time.
Oil Replacement:
To gain access to the oil intake remove the right side enclosure panel.
Power off the compressor and allow 5 minutes for the system to cool.
Purge the air from the system until both the gauges on the storage tank [1] and the oil-air separator unit [2] show zero pressure.
There cannot be any pressure inside the oil-air separator when the intake cap is removed.
IMPORTANT: Before removing the cap to the oil intake, make sure that there is no residual pressure inside of the compressor. This can be verified from the pressure gauge [2] on the oil-air separator unit and the pressure gauge on the air tank [1].
After you have verified no pressure in the compressor, use a wrench to remove the oil intake cap [1] and inspect the oil level gauge [2] to check how much oil should be added.
To drain the oil, use an adjustable wrench to remove the discharge cap [3] and then open the oil discharge valve [4] to allow oil to drain the compressor.
Allow some time for the oil to fully drain from the compressor system, then close the discharge drain.
Add oil into the intake port [1] so that the level is close to the upper red line on the oil level gauge.
The HAC15 requires around 7 quarts of oil for each oil change.
Make sure to reinstall and tighten the oil intake cap after adding the oil.
Note: It is recommended to use Mobil Rarus 427 oil for the air compressor.
Important: The oil needs to be changed after the initial 500 hours of run time and then every 2500-3000 hours of use.
If the compressor is only being run for a few hours a day, it's recommended to change the oil every 6 months.
Important: Different brands of oil cannot be mixed. Make sure the oil being used is suitable with the ambient temperature of the air compressor.
Oil Filter (09-0965):
The oil filter is located above the compressor motor, in front of the left side of the cooling unit.
To access the oil filter, remove the front enclosure panel. The filter cartridge is shown in the image [1].
To replace the oil filter, unfasten the filter by manually turning it and order part 09-0965.
Note: A strap wrench may be needed to remove the filter cartridge
Prior to installing the new filter cartridge, make sure to lubricate the sealing gasket to ensure a complete seal and prevent any leaks.
Air Filter (09-0967):
To replace the air intake filter, remove the front enclosure panel and remove the cover of the air intake.
The air intake is located directly above the compressor screw assembly.
Remove the cover [1] by rotating the cover.
Remove the filter element [2] to replace it with the new filter.
Reinstall the air intake cover and verify it is tightened by aligning the arrows [3].
Note: Replace the filter element in accordance of the Maintenance Schedule above. Replacement filters can be ordered as part number 09-0967.
Oil-Air Separator Filter (93-4388):
Shut down the air compressor and allow at minimum 5 minutes before performing any maintenance. The compressor needs to be de-pressurized before removing any fittings.
To gain access to the oil-air separator, remove the right and rear enclosure panels from the compressor.
Disconnect all pipes and valves connected to the cover plate[1] of the oil-air separator. Unfasten the 8 bolts [2] from the cover plate, and remove the plate to access the filter element [3].
Note: Before replacing the filter element make sure to lubricate the sealing gasket.
Oil-Water Separator Filters (09-0791):
The oil-water separators are located on the back of the air dryer unit.
To replace these filters, unfasten the bottom cannisters [1] by rotating them counter clockwise. Once removed you will see the filter elements.
Note: The filter elements are not identical. Make sure the correct filter is installed on the correct component as shown in the image. Filter [2] is for the left separator component and the filter [3] is for the right separator component.
Unfasten the filter element. When installing the replacement filter, make sure that the filter is fully tightened and that the gasket is in place.
Drain Oil-Water Separators:
Use the red ball valves [1] to purge the water in the oil-water separators into the discharge container.
Note: These ball valves should be opened weekly depending on compressor usage.
Important: After opening the valves until the water is drained, make sure to fully close the ball valves before using the compressor again.
Radiator:
Inspect the radiator vents for cleanliness every week.
To access the radiator, remove the front and rear enclosure panels.
The radiator is located above the compressor motor as shown in the image [1].
The radiator vents can be cleaned with either compressed air or a soft fiber brush. Not cleaning the radiator can decrease the cooling efficiency of the system.
Note: Do not use water or a steel brush to clean the vents. The electrical cabinet is located beneath the radiator that can be damaged by water or other liquids.
Clean Mesh Purge line Filter:
The purge line for the air tank and the dryer are teed together and connect to the purge manifold shown in the image.  There is a mesh filter inside the brass y-strainer [1] located before the timer solenoid [2].
Close the black valve [3] at the start of the y-strainer.
Press the test button [4] on the timer solenoid so that the compressed air is purged from the y-strainer and the drain line.
Once the cap [1] is unfastened, remove the mesh strainer element [2] so that it can be cleaned.
Rinse the strainer in water and then blow it with compressed air until it is sufficiently clean.
Reinstall the strainer and cap into the brass housing [3]. Tighten the cap and then open the valve [4] so that the purge system can begin draining water again.
Note: Make sure that the O-ring [5] is installed and that nothing leaks from the cap once tightened.
HAC30-VS - Maintenance
Revision A - 11/2025
Overview
This chapter provides information on what maintenance is needed for a HAC30-VS unit. There is a maintenance schedule as well as instructions on how to perform the required maintenance below.
  • Check oil level
Oil Replacement:
Note: It is recommended to use 09-0966 which is an ISO VG 100 viscosity oil.
Important: Different weight oils cannot be mixed. Make sure the oil being used is suitable with the ambient temperature of the air compressor.
Oil Filter (09-1137):
To replace the oil filter, unfasten the filter by manually turning it and order part 09-1137.
Note: A strap wrench may be needed to remove the oil filter cartridge.
Air Filter (09-1136):
Remove the cover [1] by releasing the latches [2] holding the 2 piece housing together.
Remove the filter element [3] to replace it with the new filter.
Reinstall the air intake cover [4] and verify that the latches are tightly secured.
Note: Replace the filter element in accordance of the Maintenance Schedule above. Replacement filters can be ordered as part number 09-1136.
Oil-Air Separator Filter (09-1135):
Radiator:
4.3 HAC15 - Service Parts List
HAC15-FS & HAC15-VS - Service Parts List
Revision D - 02/2026
Machines Part Number DESCRIPTION
HAC15-VS and HAC15-VS-FS 09-0965 OIL FILTER, AIR COMP, HAC15
09-0966 OIL, AIR COMP, HAC15
09-0967 AIR FILTER, AIR COMP, HAC15
09-0791 OIL-WATER SEPARATOR FILTERS, HAC15
08-1974 OIL CHANGE KIT, AIR COMP, HAC15
93-4388 Screw Compressor Oil-Air Separator SVC
93-4892 ACCESS PANEL LATCH HAC15
93-5092 CROSS SUPPORT REAR HAC15-VS/FS
93-5093 TOP COVER HAC15-VS/FS
93-5263 HAC15-VS/FS BREAKER
93-5290 RIGHT DOOR PANEL HAC15-VS/FS
93-5291 REAR DOOR PANEL HAC15-VS/FS
93-5292 LEFT DOOR PANEL HAC15-VS/FS
93-5448 OIL INTAKE CAP WASHER HAC15-VS/FS
93-5464 HAC15-VS/FS O-RING 85MM ID X 2.62MM CS
93-5637 KEYED LATCH PANEL CE HAC15-VS/FS
93-5641 HOSE HAC15-VS/FS
93-5642 Y FITTING HAC15-VS/FS
93-5662 MOTOR FIXED SPEED HAC15
93-5663 MOTOR VARIABLE SPEED HAC15
93-5856 TIMING SOLENOID HAC15
93-5882 AIR SCREW ASSEMBLY HAC15
93-5883 VARIABLE SPEED DRIVE HAC15
93-5884 AC CONTACTOR HAC15
93-5934 MAIN CONTROLLER HAC15
93-5959 AIR PRESSURE VALVE HAC15
93-6018 AIR INTAKE VALVE HAC15
93-6026 AIR PRESSURE VALVE PLUG HAC15
93-6027 AIR PRESSURE VALVE FITG ADAPTER HAC15
HAC30-VS - Service Parts List
Revision B - 12/2025
HAC30-VS 09-1137 30HP OIL FILTER
09-1136 30HP AIR FILTER ELEMENT
09-1135 30HP OIL AIR SEPARATOR ELEMENT
93-5869 OIL-WATER FILTER HAC30
93-5868 MOTOR VARIABLE SPEED HAC30
93-5870 O-RING INTAKE COMPRESSOR HAC30
93-5872 DOOR PANL RIGHT HAC30
93-5871 DOOR PANL REAR HAC30
93-5873 DOOR PANL LEFT HAC30
93-5874 TOP COVER PANEL HAC30
93-5875 ELECTRICAL BREAKER HAC30
93-5885 VARIABLE SPEED DRIVE HAC30
93-5861 HOSE Y-FITTING TO TANK HAC30
93-5886 AIR INTAKE ASSY HAC30
93-5887 AIR SCREW ASSY HAC30
