4 - HSF-325 - Maintenance
HSF-325 - Operator's/Service Manual
  • 1 - HSF-325 - Introduction
  • 2 - HSF-325 - Installation
  • 3 - HSF-325 - Operation
  • 4 - HSF-325 - Maintenance
  • 5 - HSF-325 - Troubleshooting
  • 4.1 Spare Parts List
  • 4.2 HSF Panel Control PCB - Replacement
There are two versions of the HSF-325; one is 230V (09-0020), and the other is 400V (09-0036). Some of the service parts are interchangeable between the two versions and some are not. Review the tables below to verify the exact replacement part.
Spare Parts List For Both 230V and 400V
PART NUMBER Vendor ITEM DESCRIPTION
93-3338 M-FUSE HSF-325 MAIN POWER FUSE HOLDER
93-3341 S-FUSE HSF-325 SUB FUSE HOLDER
93-3342 CF1 HSF-325 CONTROLLER COOLING FAN
93-3343 CF2 HSF-325 IGBT COOLING FAN
93-3344 GTS9000-5 PCB HSF-325 IGBT OVERHEATING DETECT PCB
93-3345 M-V1 HSF-325 ELECTROMAGNETIC VALVE
93-3557 TM1 HSF-325 TM1 3-PHASE POWER INPUT
93-3558 FILTER HSF-325 EMI FILTER
93-3559 BD HSF-325 BD 3-PHASE RECTIFIER
93-3560 CM1 HSF-325 CAPACITOR MODULE CM1
93-3563 SO2 HSF-325 HEATING HEAD OUTPUT SOCKET SO2
93-3565 PDC HSF-325 PDC ACDC 12V POWER UNIT
93-3566 GTS9000-1
PCB
HSF-325 GTS9000-1 PANEL CONTROL PCB
Parts That Are Unique to 09-0020 (230V) or 09-0036 (400V)
PART NUMBERS for 09-0020 (230V) PART NUMBERS for 09-0036 (400V) Vendor ITEM DESCRIPTION
93-3337 93-4463 P-SW HSF-325 POWER ON/OFF SWITCH
93-3339 93-4471 CT1 HSF-325 CURRENT SENSOR 1
93-3340 93-4472 CT2 HSF-325 CURRENT SENSOR 2
93-3346 93-4476 L-Size Heating Head HSF-325 LARGE SIZE HEATING HEAD
93-3561 93-4484 CM2 HSF-325 CAPACITOR MODULE CM2
93-3562 93-4473 SO1 HSF-325 HEATING HEAD OUTPUT SOCKET SO1
93-3564 93-4474 PT HSF-325 PT POWER TRANSFORMER
93-3567 93-4475 GTS9000-2 PCB HSF-325 GTS9000-2 MAIN CONTROL PCB
93-3568 93-4470 GTS9000-4 PCB HSF-325 GTS9000-4 IGBT MODULE PCB
AD0572
This procedure will explain how to replace the HSF Panel Control PCB, this should only be performed by a Haas Certified Technician.
Please contact Haas Service to replace this board.
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Replacement
Remove the screws that hold the front panel from the bottom of the machine and slide out the front panel.
Remove the ziptie on connector [1] and disconnect the cables shown before completely sliding out the front panel.
NOTE: Hot glue may be present on the connectors remove the hot glue without damaging the cables or connectors.
Remove the plate covering the PCB [1] by removing the nuts [2] holding the plate to the standoffs.
Unscrew the standoffs [1] from the PCB, there should be only one nut in place of a standoff on the PCB [2].
Unplug the STOP button before removing the PCB.
Be careful not to drop the washers under the PCB when removing the old board.
Replace the old PCB with the new one and verify that all the springs on the buttons [1] are in place.
To complete the installation do all these steps in reverse.
Power on the HSF and test that all the buttons, stop button and display are all working correctly.
