2 - HSF-325 - Installation
HSF-325 - Operator's/Service Manual
  • 1 - HSF-325 - Introduction
  • 2 - HSF-325 - Installation
  • 3 - HSF-325 - Operation
  • 4 - HSF-325 - Maintenance
  • 5 - HSF-325 - Troubleshooting
  • 2.1 HSF-325 - Installation
HSF-325 Setting Up
This procedure will show you how to install the HSF-325 Induction Shrink Fit Machine.
What comes in the package
  • Main unit ×1 (guide rail and heating head)
  • Tool sleeves (as ordered)
  • Main power supply cable ×1
  • Spare fuse
  • Pickup springs: 4 mm ×2; 6 mm ×2; 8 mm ×2; 10 mm ×2
  • User’s Guide ×1
Install the up/down guide rail.
Fasten the rail to the base with the provided screws.
Attach the heating head to the holder on the guide rail.
Connect the heating head.
Connect the hose for the cooling air.
Note: The max air pressure for the HSF-325 is 100 PSI. Haas CNC machines use air pressure between 80 and 120 PSI. If the shop air is on the higher end of this range, a regulator will need to be added.
The pressure can lowered below 100 PSI to make the operation queiter. This will mean that tools will need more time to cool down, and an increased possibility of overheating the heating head getting alarm E2.
Install the toolholder sleeve.
Install the protective cover.
Connect the main power supply: 3-phase 220VAC
(ensure there is a proper ground connection)
